Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 08-06-2005, 05:47 PM
Tartop Tartop is offline
Question Low tire pressure warning light 98 Continental
I bought this car used and the previous owners replaced the tires with something other than the run flat tires that this sensor regulates. There is proper tire pressure but the light will not go off. How do I bypass this until I replace the tires, which will not be for some time?
Old 09-15-2005, 03:09 PM
jetchief jetchief is offline
Lincoln warnig light.
I have the same problem. Hope someone has an answer
Old 09-15-2005, 08:13 PM
Towncar's Avatar
Towncar Towncar is offline
I getting the general consensus that the warning system may be controlled through your Radio console.
Reference shows the instruction to operate and/or disable the system is in your owners manual.
There's almost always a few of these offered around eBay.
-Steven
1996 Town Car, Cartier
Old 09-16-2005, 01:25 PM
Hey Towncar
Thanks I'll look for one. I have a 95 shop manule but it didn't come out till 96
Old 09-16-2005, 01:26 PM
Hey Towncar
Thanks I'll look for one. I have a 95 shop manual but it didn't come out till 96
Old 09-16-2005, 01:46 PM
Towncar's Avatar
Re: Low tire pressure warning light 98 Continental
Originally Posted by jetchief
Hey Towncar
Hmmm,
I have the 1996 manual. Didn't even think of looking in there since this thread referenced 1998 -- I'll hav a look and reply.
PS Would you like a CD copy of my 1996 manuals? Their about $5~10 on eBay every day.
-Steven
Old 09-16-2005, 03:29 PM
Town Car
I have the 96 Continental owners manual that came with the car, but it dosen't say anything about turning it off. If you have one that says anything about it let me know and I'll see if I can find one .
Andy
Old 09-16-2005, 05:25 PM
Towncar's Avatar
Town Car
Andy
Now I'm reading some additional information. In 1996 (that's where I have the ability to read) the Low Pressure Sensor is inside the wheel, and it's a Transmitter. Four of these Transmitters are mounted, one inside each wheel, which monitor nothing but tire (air) pressure, regardless of what type of tire is mounted.
If the transmitter isn't sending data, it's either damaged or removed.
The "Securitire Tire" has the properties to be driven flat for some specified distance (about 20 miles) however, it has no effect on the Low Tire Pressure Warning System.
There's very specific tire dismounting/mounting instructions provided to prevent an installer from damaging the Transmitters. If the instruction isn't followed to the T, damage will result.
Ref: 1996-Conti-Tires and Wheels, Removal and Installation, Tire Section.
Like you folks, I don't see a procedure for disabling the Low Tire Pressure Warning System however, there is reference to:
  • Removing Low Tire Pressure Warning System Module
  • Removing/Changing Low Tire Pressure Warning Light Bulb
Some or all of these procedures should answer any further questions you may have, and aid you in temporarilly disabling the system. If it were me, I'd just remove the bulb.
Low Tire Pressure System Indicator Bulb
1. Disengage and lower (do not remove) console finish panel from roof console.
2. Twist and pull bulb socket from bulb housing.
3. Remove miniature bulb from bulb socket.
4. To install, reverse Removal procedure.
Overhead Console/Switch Assembly
1. Disengage and lower (do not remove) console panel finish panel from roof console.
2. Disconnect wire harness connector. Remove two retaining screws and low tire pressure module from roof console.
-Steven
Old 09-16-2005, 06:02 PM
Thumbs up
That answeres my question. Thanks for the info. I'll try it. My sensors work fine. I'm just going to be using different tires and wheels and don't want to continually get a low pressure waring. Thanks again
Andy
