Terrible Ride
I just recently lowered my 2 wheel drive blazer with blocks for the back and new springs for the front. I knew that it would make the truck ride alot worse but I didn't expect it to be this bad. Is there anything I can do to make it better. And yes it has 20" rims and low pro tires.
Re: Terrible Ride
Get an alignment done ASAP.
Also, grease your front end. 10-11 grease fittings to fill with grease. Do the u-joints as well. I don't know why you are complaining about the ride, you knew it would stiffen it up a lot.
1995 Factory Blazer Service Manual for sale, PM if interested. |
I ain't complaining I just needed some suggestions..
Re: Terrible Ride
is it noisy or just rough?
I would say its the rims and tires that f'dup your ride the normal 75 cm tall tire have "bounce" in them which makes the ride smoother when you put low pro's with 60 + psi it has no more "bounce" and makes the ride stiff. theres no fixing it all you can do is deal with it and grease everything hoping it will fix it but it wont.
It's not noisy except for the shit that is inside of the car it is just really rought.
