Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-06-2005, 03:00 PM
eclipse_line007 eclipse_line007 is offline
air sensor needed???
here's a problem...recently, i bought a 94 eclipse gs. then i also got a intake for it. however, when i installed the intake, i took out the air sensor. is that a problem? im a nOOb with cars, so im not sure if the air sensor is needed.
Old 08-06-2005, 05:49 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: air sensor needed???
yea it needs to be there. get a k&n drop in filter and just use the hard pipe to go from the thottle body to the back of the air sensor
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 08-07-2005, 07:34 PM
are you serious....damn...wat would happen if it is not used?...as of right now?...im not using it...am i in trouble?....plus, in order to connect the sensor to the intake, i need one more of those plastic tubes, the thing that connects the throttle body and intake...but i only got one with my intake...sh!t....is there a way to do sumthin to the senor and make it less of a problem?
Old 08-07-2005, 07:38 PM
sorry for the double post, but since im here, i might as well ask...how much horsepower does a 94 eclipse with a 4g63 engine has?
