Old 08-06-2005, 11:54 AM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Mechanical engine noise - 3 cyl 1.0 L. ?
My '93 Metro has the 1.0 L, 3 cylinder engine.
The mechanical engine noise is quite loud - not the firing of the
cylinders!
The rockers, the belts, whatever - are quite loud.
I know some engines make noise like a chainsaw when you get
near them as at a stoplight.
I Know that if it were really bad, the engine would not have run
for the 4 thousand miles I've put on it without dying.
Is it normal for those small engines to make all sorts of, what I call,
grinding and scraping noises?
Sounds like a kitchen mixer while it scrapes the metal bowl....
Bugs the hell out of me - I am a noise worrier.
DoctorBill
Old 08-08-2005, 11:22 AM
Mike_Van Mike_Van is offline
Does it sound like a bad bearing?
Does the sound change when rev's increase?
Old 08-09-2005, 01:34 AM
DOCTORBILL's Avatar
Geo Metro Lover
Re: Mechanical engine noise - 3 cyl 1.0 L. ?
REVS - no, just drowned out by the normal engine noise.
I don't know... That is what I am trying to find out from others.
I would describe it as sounding like an Electric Chain Saw -
you know - sound of the chain w/o normal engine noise.
A lot seems to come from the valve cover. If I open the
oil adding cap while the engine runs - WOW! Very loud.
What would the bearings for the cam shaft going bad sound like?
It is VERY loud before the engine warms up. Still noisy all the time.
If I listen on the left side down by the water pump/alternator,
it sounds like a chain saw blade spinning.
This has been going on for 4,000 miles, so if it was a bad thing,
I suppose the engine would have "broken" somewhere...!
I replaced the timing belt and tensioner pully 4k miles ago,
and am wondering if the tensioner pully is noisy - or the belt itself?
I just don't want some Catastrophic failure to occur out on some
lonely road in the middle of the night.......
DoctorBill
