Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 08-06-2005, 11:11 AM
james kremer james kremer is offline
temp gauge wont work
93 ts with 3.8. istill cant figure out why my temp gauge wont work. i have my fans hard-wired right now but have forgotten to turn them on more than once. it's been over 110 out lately,so i really need to figure this out. any help would be great. thanks.
Old 08-06-2005, 11:57 AM
cdru's Avatar
cdru cdru is offline
Re: temp gauge wont work
Does your sensor test correctly? Typically the sensor is just a thermistor (think thermo resistor). The resistance across two pins varies as the temp rises and falls. If that tests ok, then you'll just have to start backtracking the wires seeing if there is a broken wire somewhere.
Someone with a 93 repair manual will have to look up the specific values the sensor should read and the pin outs. Or you could just get a Haynes manual.
Old 08-07-2005, 08:00 PM
yellowfiero yellowfiero is offline
You could also put a dummy resistor in to see if the gauge will work.
