Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-06-2005, 02:27 AM
guitardude9000 guitardude9000 is offline
Send a message via AIM to guitardude9000
Coolant leak
I bought my 1993 civic dx a couple weeks ago. I found it has a coolant leak coming from the water pump or the water pump seal. If anyone has advice on fixing it or diagrams that show how everything goes together please send em. THANX LATER
Old 08-09-2005, 12:11 AM
BullShifter's Avatar
Re: Coolant leak
It's very involved. I highly recommend a repair manual since you will be removing the timing belt. Repalce the timing belt at the same time, a wet belt is weak. If it breaks it could cost you a new engine.
Fix it ASAP!
I could give step by step intructions but I don't want to be responsible if you screw up. Timing belts are nothing to mess with.
Old 08-15-2005, 08:26 PM
ricebrnr13 ricebrnr13 is offline
Re: Coolant leak
go to www.clubsi.com in the forums under N/A tuning there is a full service manual for civics. good luck.
