What's causing sound/vibration
I have a 96' blazer and when I turn all the way to the right (not left) i get a humming noise and a very subtle vibration comming from my right wheel well. I'm sure it is not the tire rubbing cause i'm only using 30x9.5" tires on my stock blazer. please advise!
I had the same noise/vibration with my 2000 Blazer. I can't say this is the exact problem you've got, but check it out. I also only have a 30" x 9.5" tire and it started off as just a little noise and rub, then got loud. It was only when I turned left. If you look at the wheel well when the tire is turned all the way to right, there may be a little (or big) dent in the wheel well pushing out in some place that will hit the tire. Compare your left and right front wheel wells. If it's sticking out, there's your problem. Too fix this, I just took the wheel off and took a rubber mallet to it. Can't gaurantee this is your problem, or if it is, I can't gaurantee this will help.
K&N won't honor my warranty because I have 1,000,007 miles on my Blazer
Re: What's causing sound/vibration
What speed are we talking about here?
1995 Factory Blazer Service Manual for sale, PM if interested. |
For me, "pulling into the driveway" speeds. (the whole front going down then up into the driveway.)
CV joint may be bad, check for tear in the CV boot.
Re: Re: What's causing sound/vibration
It is that or your bearing.
Also, you might want to grease your front end. There are 10-11 grease fitting you should do every oil change. And no, you don't trust the oil change place to do it. They might hit 6 of them MAX.
thanx for the info on the grease fittings, it seemed to have helped
sahweet!
