Old 08-05-2005, 09:15 PM
scottsdale scottsdale is offline
96 grand prix no a/c
I have 96 grand prix 3.1 that the a/c has stopped working.It is full of freon,checked fuses all ok,changed relay in underhood box,changed pressure switch,still no air.The compressor is not getting any fire to it.Is there any other relays to check or will it be the control panel.Everything else in control panel works,even light comes on for a/c.The cooling fan that comes on when the a/c is switched on is not coming on either.If anybody can help please respond.Thanks
Old 08-06-2005, 10:55 AM
ctesla's Avatar
ctesla ctesla is offline
Re: 96 grand prix no a/c
the pressure switch, is the one tapped into the high side pressure hose, correct? unplug that and use a wire to jumper those two connections in the plug. the compressor should kick on, and then see if your getting cold air in the cabin...
if so, clogged orifice tube? bad pressure switch? do you have a set of gauges? does the low side have an over-charge condition? I'll be the first to admit, that if you have exhausted all means, it might be time to take it to a specialist... I know, labor costs what they are, but A/C is worth the comfort, and if it is something internal, the cost of the shop is almost what it would cost to purchase 134 and re-fill the system.
