Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 08-05-2005, 09:02 PM
passati passati is offline
2000 Passat Driver Door Alignment
Wind caught the door and pushed it open, hard. Now the door seems to be sagging a little. It closes hard and there are signs of wear on the striker. Anyone know how to adjust the door?
Old 08-07-2005, 03:06 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
I believe its a 10mm triple square socket that you use to loosen up the striker a little then tap it with a small hammer to move it arround ( move it in to make the door go in, move it out to make the door go out, when its closed that is).
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 08-11-2005, 09:49 PM
Thanks! The problem seems to be with the hinges since the door does not fit into the opening properly. I can lower the striker plate but the door will still sag in the opening. Do these hinges wear out or break? Can they be ordered and replaced?
