Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 08-05-2005, 07:15 PM
Xenos132 Xenos132 is offline
92 Plymouth Sundance starting problem.
I can only get 6vdc to the ignition coil. From the main wire to ground I will get 12vdc however across them I only get 6. When I ohm out the ground wire ( grey) it shows 900 ohm’s to ground. Does anyone have some advice or a diagram? Am I correct assuming I should have 12vdc on the primary of the coil?
Old 08-08-2005, 12:04 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 92 Plymouth Sundance starting problem.
if you have 6 volts, you have a bad ground. Check the ground side of your primary ignition voltage. Also, your meter is reading a median voltage for your primary igniton circuit. The voltage should flutuate between -200volts to 30 volts as the magnetic field inside the coil winding collapses.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
