Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 08-05-2005, 06:51 PM
latino26 latino26 is offline
Unhappy fuel problem
hey guys i did changed the injectors but have same problem. i also changed my fuel pump no luck so im back to drawing board. so if anybody has some idea please help me out. i got this car 5 month ago and never even herd it run for one minute maybe by some chance ill could get it running with your guys help please. thanks for checking the post.
Old 08-05-2005, 11:11 PM
flyinMKIV's Avatar
flyinMKIV flyinMKIV is offline
AF - Advisor
Send a message via AIM to flyinMKIV
Re: fuel problem
umm, what is the problem? You mentioned a fuel problem in the title. Be a little more specific.
02 Honda Accord (Sold)
93.5 Supra non-turbo (Sold)
94 Lexus GS300: 2jzgte swapped (sold)
08 Scion TC (daily driver)
94 Supra Single Turbo (Sold)
97 Top Secret Widebody Supra Turbo (Work in progress)
If your talking trash, I'll be showing my ass
http://www.automotiveforums.com/vbul...d.php?t=535850
http://www.automotiveforums.com/vbul...d.php?t=212356
Old 08-05-2005, 11:18 PM
Re: fuel problem
the problem i have is that my supra isnt getting fuel past my injectors
i have presure in the fuel rail but from that point on no good it starts for a half min because the cold start injector but the injectors doent want to take over so she stalls.
Old 08-06-2005, 02:24 PM
flyinMKIV's Avatar
AF - Advisor
Re: fuel problem
what size injectors are you running? and are their any other modifications done to the fuel system?
Old 08-06-2005, 08:04 PM
Re: Re: Re: fuel problem
stock injectors.i have done no mods until i get it running everthing in engine is all stock.like i posted the first time the car was running good until he hooked the battery up wrong since then it havent ran. i checked all the fuses and relays everything seems to be good checked my wires as well.
and still nothing its crazy because it runs off the cold start injector which starts the car then the injectors are sopose to take over but they dont it shuts off.do you think it could be the ecu thats bad.
or maybe the efi resistor im not sure what these items would cause im just trying to think of some thing.thanks for taking the time to stop bye i really could use some help.
Old 08-22-2005, 04:55 AM
4cd30l 4cd30l is offline
Re: fuel problem
are the injectors pulsing cause i have that problem at the moment it could be wires or a computer
Old 08-22-2005, 11:49 PM
no they are not thats why im thinking ecu.but im not 100% sure.
Old 08-24-2005, 04:14 PM
GadflyII's Avatar
GadflyII GadflyII is offline
Re: fuel problem
well, it is either your harness, or your ECU.
I would check where the wiring harness connects to the ECU, if it had an aftermarket computer, such as an AEM, MOTEC, or even an E-manage they may have but the injector wires.
94 Supra Turbo 6spd
Ported head w/ 1mm over sized valves
6pt cage w/ removable door bars
SP67 Single Turbo .81 A/R
RPS Manifold
SP fuel sys w/ 1000cc injectors, SP rail, & Dual Walboro pumps
Aeromotive FP regulator
Greddy 3 Row front mount
Tail BOV
TRD Rear Diff
TRD dual disk clutch
HKS Racing Wastegate
HKS DLI
HKS VPC
HKS BCC
HKS EBC
FJO Wideband o2
Greddy Electronic Boost, EGT, Fuel pressure w/ Peak & hold
98 tail and headlights
Wings West lip
Old 08-25-2005, 05:55 AM
Re: fuel problem
hey it was my wiring harness one of the wires were stuffed thatnks for ya help its running good now only 5 psi though should turn it up hehehe
