Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 08-05-2005, 07:34 PM
slideways...'s Avatar
slideways... slideways... is offline
just wanted to make sure
will the nx2000 big brake upgrade work on a b15? its a 2001 SE and has the sport package with the 16" SE-R rims so wheel clearance should be good. not sure about anything else though. dont want to rip it apart just to find out one bolt hole is 1/2" off or something
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 08-06-2005, 06:08 PM
SR20B12's Avatar
SR20B12 SR20B12 is offline
Re: just wanted to make sure
use the brembo's for the SE-R spec V better than the NX2000 old school up grade.(91-94) the car is newer so the aftermarket stuff for the spec v is there to use. just saw a DIY auto show on the Spec Vbrake upgrade using the brembo's too.
B12 coupe w/SR20DE
91 AE92 Daily Grinder.
Old 08-08-2005, 01:15 AM
ummm brembos really work?
i just assumed the 5lug specV had totally different hubs than the 4 lug SE
and plus, this is a friend's car and she doesnt wanna spend that much money. she really just needs pads and rotors but i convinced her to get the nx upgrade if it works
Old 08-08-2005, 07:05 AM
SR20B12's Avatar
ahhh.... Well if I would learn to read.. I forgot the spec has 5lug... I had spec V on the brain. IIRC the nx AD22 has an ABS/nonABS check with fast brakes. www.fastbrakes.com sorry for the dumb moment
B12 coupe w/SR20DE
Old 08-12-2005, 02:00 AM
whether the NX or sentra has ABS doesnt matter.
ABS is really just part of the hub/axle, not the caliper
im just wondering if the caliper will bolt to the hub and the rotor will fit(i mean if the caliper bolts on the hub are too far in or out the caliper wont fit over the rotor correctly)
and fastbrakes only has 700$ 4piston caliper kits and the like...i couldnt find anything on NX upgrades
im trying to spend only a couple hundred tops on this. if she wanted to fork out some dough id get the 4 piston already but as it stands the options are between this and stock pad/rotor replacement
Old 08-14-2005, 11:47 AM
anyone else wish to comment on this?
anyone whos tried it maybe?
