Old 08-05-2005, 06:32 PM
disturbedbmx1 disturbedbmx1 is offline
car stalling out not starting up
this is my first time here and i lobe this site already but straight to what i need help with i have a 91 rs v8 vin code E and i jus did a whoel tune up plugs wires yadda yadda computer ignition sencor and it started right up but after a week the rpms went down at idle timed it out perfect still doin it last night my car stalled 4 times and befor it stalled i would hit the gass and it would spuddle like it wanted to go but woudlent hen it would catch and run fine then stall and when i try to start it it would start then stall right away and now it jus wont strat can someone please help me with this car is gorgeous and got low miles i dont want to get rid of it
Old 08-10-2005, 09:02 AM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
Re: car stalling out not starting up
Well if it ran fine before and you just put a tuneup on it,try a new fuel filter and then test the pump to see if it is working right.And if that don't work try to have the throttle position sensor tested. then get back to us if that don't work. check all your plug wires .
This is what 500 plus hp looks like.CNC ported AFRHEADS WITH 2.02 INT 1.60EXH,210 intake runners 74cc chambers, 750 speed demon carb,weiand intake,comp cams 292 with .501/.501 lift ,4340 forged crank,eagle H-beam rods duroshield bearings,KB forged 10 1/2:1 pistons,headers with 1 3/4 primaries ,MSD 6AL,comp cams pro mag1.6 rockers,holley blue pro-series pumps,MSD billet distributor.All stuffed into a 355.[img][/img]
Old 08-10-2005, 08:32 PM
Re: Re: car stalling out not starting up
i jus a new filter on and the pump is fworking fine pushing gas right out now how would i check my censor get back to me and thanks ur the only one to comment in days thanks man
Old 08-11-2005, 12:44 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
You hinted something about timing, did you tighten down the distributer hold down? Follow the inst. on settin gthe timing?
Old 08-11-2005, 02:09 PM
victimizati0n victimizati0n is offline
Send a message via AIM to victimizati0n
i would love to help you out, but i cant understand what you are saying.
Old 08-12-2005, 07:08 PM
i did a whole tune up and cmputer ignition sencor the whole 9 yards and the fuel filter the fuel pump is fine pushing gas like its surpose to did the timing put it to 0degrees in drive like it said and i jus doubled checked and it is tight im not to sure what else can be wrong u guys think it could be the choke body or some kind of sencor
Old 08-12-2005, 08:02 PM
Morley Morley is offline
Re: Re: Re: car stalling out not starting up
Computer ignition sensor?
Choke body?
What he was getting at about not being able to understand is...,punctuation, spelling, capitalization, etc...
I'm not usually one to get on the grammar/spelling kick...but the first post made my head hurt.
Slow down, collect your thoughts and proof read what you wrote before hitting the submit reply button.
Old 08-14-2005, 12:41 PM
yea i jus kinda in a rush when i was writing it sry but did u guys understand it enough to know what im talken about or do u guys need me to rewrite it
