Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 08-05-2005, 04:56 PM
angels7113 angels7113 is offline
Gen 1 jdm b16a tune up
I just put in my generation 1 jdm b16a a couple of weeks ago and i was going to give it a tune up, but i'm not sure what motors plugs distributor and rotor would match with mine. Would a early 90 integra match up.
If anyone else has one i would appreciate if you could tell me some places to get parts. Because i'm totally lost? I guess i didn't think this one through. Thanks for any help.
Old 08-05-2005, 07:46 PM
Red B16A's Avatar
Red B16A Red B16A is offline
Re: Gen 1 jdm b16a tune up
Pretty much all the stuf you would get is what is on a 94 or 95 del sol with DOHC VTEC. Thats all
95 JDM B16A Hatch DX
Stage 2 Zex Cams
comp cams 913 springs and retainers
professional products intake mani
68mm throttle body
ZR racing header
Handata s200
Password JDM intake
Old 08-05-2005, 07:52 PM
QUICK_EG_B16A QUICK_EG_B16A is offline
Well on my jdm b16 (2nd gen I think,... it has a hyrdo tranny) I was able to use several integra and delsol vtec pearts when I did my tune up heres what i did:
Denso N/A heat range plugs, they make different plugs for FI motors (MUCH better than the NGK Rs that were in it originally)
Magnacore wires
and then checked the rotor and distributor(didn't replace them though as they were and still are in perfect working order)
After this it idled much smoother and seemed to even accelerate quicker.
Old 08-06-2005, 02:13 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
jdm b16 sir 1
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Bitch Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 10-07-2005, 05:27 PM
amadriga amadriga is offline
You can use distributor cap and rotor froma 88-91 Civic.
Old 10-07-2005, 05:49 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Re: Gen 1 jdm b16a tune up
Originally Posted by superbluecivicsi
jdm b16 sir 1
this should be stickied!!
