Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-05-2005, 04:02 PM
terpsfan88 terpsfan88 is offline
Question 95' Thunderbird Super Coupe
Im looking to buy a 95' thunderbird super coupe with 113,000 miles on the tranny and body and a fairly new motor with 13,000 miles. The only thing wrong with it is the radio doesnt work and drivers window motor occationally stops working. Would it be worth paying $2,500 for and what known problems should I look out for? Any help would be appreciated. Thanks
Old 08-05-2005, 06:59 PM
Jim Adams Jim Adams is offline
Hello!! I have a 1989 Tbird Supercoupe with 80k original miles it is fully loaded and has a stick shift I have the original window sticker from when it was purchased new and it was 25 grand ,,these cars are expensive I would assume that you have a pioneer radio and it has a amplifier that is located under the package shelf in the trunk ,,this is usually the failure with these radio,s. The window motor is probably an easy fix they can be bought for about 40 bucks or so new at auto zone. If it has good oil pressure when it gets hot and the Supercharger isnt real noisy ( a little noise is typical) and the tranny is tight then buy it cause I wouldnt sell mine for 2500 and its an 89 lol,,enjoy the car they run strong and have unlimited top end ,,I have had mine up around 130 and had more to go.
Old 08-06-2005, 10:24 AM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: 95' Thunderbird Super Coupe
I got my 93 for 2500...
But the the window is an easy fix. AND FREE. If you decide to buy it, post another thread, and I can help you out.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 08-06-2005, 05:18 PM
95 super coupe
hey thanks alot, im goin to check it out on sunday, then ill be back and post somethin for you guys.
PS:i think this guy has the stock radio in it and i dont know if its the radio going bad or the wiring, but i have my own headunit, subs, and amp that i plan to put in it.
Old 08-07-2005, 03:16 PM
yea tell me why i test drove it and it purred like a kitten and i called the guy and he said he would sell it for $1500. but i still am goin to need to fix that window and see whats wrong with the radio, CamaroSSboy346 if you could help me out i would appreciate it. thanks
Old 08-07-2005, 03:18 PM
Re: Re: 95' Thunderbird Super Coupe
Old 08-07-2005, 07:24 PM
if you can hear the window motor trying to work then yours can be fixed,,if you take off the door panel and then pull the window motor off ,,right by the gear that drives the regulator there is three screws ,,take them out and pull the cover off,,normally you will see a bunch off little pieces of the blue barrels broke up inside there,,I found that is you get some 5/8 glue gun sticks and cut them about a half an inch long and put three of them in the opropriate spots after cleaning out the little pieces ,,put the cover back on then the window motor will work like new,,if the motor doesnt work at all or you cant hear it turning before you take it apart then you should buy a reman from auto zone ,,they are fairly cheap.
