Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-05-2005, 01:10 PM
RedLT's Avatar
RedLT RedLT is offline
OMG its smoke
I have a problem with my toy. For some reason it started smoking real bad the other day. I had it in 4HI and it was sitting kind of on a hill running. I put it in drive and started to drive off when this thick cloud of white smoke just came roaring out of my tail pipe for about 30 seconds. When I got driving down the road it went away. I switched out of 4HI when I was driving but the smoke went away before I took it out of 4HI. It has done this once before in the past when it was never in 4HI just 2WD. The first time it happened I though one of my rings was broken or something and oil was getting into my combustion chamber. Anyone (LT maybe) know why this has happened more than once??
I might as well go check my vaccum hoses and clean a few things like the EGR right now because I know LT will throw a fit if I don't after bugging him about telling everyone to check them.
So, any other suggestions beyond the obvious?
Red 1995 Chevy Blazer 4X4
Check it out.
http://www.cardomain.com/ride/2071240
MODs
Brush Guard 2/20/05
Bigger tires 3/15/05
Flowmasters 6/18/05
Minor Paint work 2005
Upcomming
6 inch lift 0-6 months
Swampers 0-6 months
Dual Flowmaster Exaust 6-12 months
Old 08-05-2005, 04:42 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: OMG its smoke
Does she smoke up on you when you first start it in the morning? Does it get better, or worse when acellerating uphill or decellerating down a long, steep hill? Is your coolant overflow tank low on fluid? If it isn't, check the radiator when the truck is stone, dead cold after sitting overnight. Is there coolant in the neck under the cap? Have you had the cooling system pressure checked for leakdown for a few hours or overnight? Have you had a cylinder compression check done?
The reason why I ask this is because the water content of the coolant can make the exhaust blow sweet, white smoke and it may be leaking past internal seals or worse, head gaskets. Oil smoke tends to be a grey-blue in color and hints at other problems. COnsider the checks I mentioned and let us know which one you have done and what the results were.
Old 08-05-2005, 04:57 PM
RedLT's Avatar
I have experianced a blown head gasket in the past. This is nothing like it. There is only the smell of exaust but its really think and white maybe grey. It has only done it twice and both times it was just ideling. My fluids are all at normal and the oil was just changed about 800 miles ago. The first time it happened my service engine light came on and I had my cat. gutted and a sensor changed then it was fixed for a while when something gave way on the interstate. I got that fixed getting a new flowmaster exaust and everythinghas been fine since then until the other day when it blew smoke out the tail pipe again for about 30 seconds. It always stops but what is causing it.
Check it out.
MODs
Brush Guard 2/20/05
Flowmasters 6/18/05
Upcomming
Swampers 0-6 months
Old 08-05-2005, 05:03 PM
wolfox's Avatar
Re: OMG its smoke
If it does it at idle, or startup - I suspect valve seals allowing oil to seep past them to be sucked in on the intake stroke of one or more cylinders. But checking/replacing your PCV first wouldbe a step in th right direction. They are quite noisy and buzzy when the engine is first started in the morning. It will quiet down as the engine warms. Do a nice long, moderate climb up a hill at highway speeds and peek in your rearview for any clouds of smoke. Reverse course and drive down that hill with your foot off the throttle to also see if this induces some smoke. But grey-blue smoke at start up or idle may be malfunctioning PCV or valve seals that are gone. Neither is a huge job to do, thankfully.
Old 08-05-2005, 08:50 PM
RedLT's Avatar
Re: OMG its smoke
Thanks for the info, I live in the mountians so that test won't be very hard at all.
Check it out.
MODs
Brush Guard 2/20/05
Flowmasters 6/18/05
Upcomming
Swampers 0-6 months
Old 08-06-2005, 12:46 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: OMG its smoke
White smoke is a coolant leak.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-06-2005, 01:08 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: OMG its smoke
white= water vapor, which is a coolent leak
bluish= oil burnoff, bad pcv or valve seals
black= rich, to much gas in the cylinder to air mixture (a/f) bad maf, iac, or even a tps to name a few
Old 08-06-2005, 10:05 PM
RedLT's Avatar
Re: OMG its smoke
Thanks
Check it out.
MODs
Brush Guard 2/20/05
Flowmasters 6/18/05
Upcomming
Swampers 0-6 months
Old 06-30-2006, 11:29 PM
vballfun vballfun is offline
Re: OMG its smoke
RedLT,
I've got the same vehicle... just different paint scheme.. red/silver... Anyway.. I just had the exact same thing you discribed happen to my blazer this week.. I was in 4HI due to some flash flooding on interstate with poor drainage.. and when I went out of 4HI to 2 WD I got the same thing.. the white cloud of smoke behind me for about 30 seconds... and went away.. next day on way to work.. i got the same thing.. and on the way home as well.. but not everytime I drive.. and it only lasts for about 20-30 seconds.. and it's like leaving a white smokescreen behind me on interstate... unfortunately I don't have any hills around here.. Va Beach... to perform the recommended test.
I was just curious what the problem ended up being and what was the fix...
Thanks,
VBallFun.
Old 07-01-2006, 06:22 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: OMG its smoke
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
Closed Thread
