Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 08-05-2005, 01:07 PM
viridion viridion is offline
Send a message via ICQ to viridion Send a message via AIM to viridion Send a message via MSN to viridion Send a message via Yahoo to viridion
single cam KA not running right
89 coupe, single cam KA.
it won't stay running, it starts, fires twice and dies.. like it's starving for fuel
if i pump it when i crank it will start and run smoothly up and down as long as i keep moving the pedal, if i stop moving the pedal it will die (doesn't matter if it's WOT, 1/4, 1/2) if i take my foot off the gas it just dies.
but when it's running it's smooth on all four cyl so i believe it's not a spark or compression problem.. any ideas?
-Josh
B18A into 90 hatch, daily driver
projects:
all kinds of fun and wierd honda projects/conversions,
funnest is SBC into 90 hatch, RWD conversion, turbo400 tranny.. it's a cut and weld thing
Old 08-05-2005, 03:12 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: single cam KA not running right
throttle position sensor
buy this one before its gone
http://cgi.ebay.com/ebaymotors/THROT...spagenameZWD1V
not sure what else it would be
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 08-20-2005, 06:00 PM
Waltz's Avatar
Waltz Waltz is offline
Post single cam KA not running right
donno how long ago you posted this , but unstable idle/stalling can be caused also by vacuum leakage or you idle air control malfunction
idle air control is a "step by step" motor that regulates hom much air is let into the intake manifold when throttle is closed ... thus if its stuck closed , then your engine gets no air when ur not pressing the gaz pedal.
Hope this helps a little , ill be looking back at this if you need any help
Old 08-20-2005, 06:16 PM
x~Underoath~x's Avatar
x~Underoath~x x~Underoath~x is offline
Send a message via AIM to x~Underoath~x
Yeah, this is just a little dated....BUT its happening SO much lately...idle problems with the KA.
This may be temporary relief...but turn the little screw next to(to the right of) the throttle body a little and open the plate up a hair, its on the thing that the throttle cables are on. Its what I did, I wouldnt suggest it, but Im only keeping it for another couple of months, so what do i care?
1990 Nissan 240sx SE(5spd)(Megan R. Coilovers)(5Zigen FN01rc 17x8 +35: For Sale)
Wanted: Some sort of 15-16x7-8" mesh wheels, black w/polished lip. And a nice offset.
DRFT 1337 [8:10 P.M.]: i figured out how to make my dick 12 inches
OurOnePassion [8:10 P.M.]: WOW
DRFT 1337 [8:10 P.M.]: fold it in half
DRFT 1337 [8:10 P.M.]: that is how i make it 12
Old 08-20-2005, 06:22 PM
Waltz's Avatar
yeah , works for a short term fix , but the iac (idle air control) is one of the thing that is of most concern for this specific problem (that and vacuum leakage)
