Old 04-30-2002, 03:42 PM
Poweredbyhonda's Avatar
Poweredbyhonda Poweredbyhonda is offline
Send a message via AIM to Poweredbyhonda
b20
Someone told me that a b20 would not fit in a 4th gen. is this true??
I mean there practicly the same size as a b18 right?
thanx !
Kyle Cox
project eg hatch in progress
http://www.nsmotosports.cjb.com
:badass:
Old 04-30-2002, 04:40 PM
EightOhOne's Avatar
EightOhOne EightOhOne is offline
it will fit fine, whoever told you that is full of shit. you do need to run a ls intake manifold rather than the stock b20 one though..
Old 04-30-2002, 04:41 PM
91zc 91zc is offline
It will fit fine. Just like any other b series motor. On one of the B20 models(giraffe intake) you will need to change the intake manifold to one off a B18b or a.
91 civic 4dr
b16a
14.8@94
Old 04-30-2002, 05:35 PM
the guy is in this forum, his avatar is a wierd lookin cat!
Well thanx guys!
Would a Cable tranny from a LS, And a Non-obd Ecu work with this swap??
if not what ECU would i use?? And how would i get around OBD?
Kyle Cox
:badass:
Old 04-30-2002, 11:35 PM
Phatwhippin_CRX Phatwhippin_CRX is offline
Send a message via ICQ to Phatwhippin_CRX Send a message via AIM to Phatwhippin_CRX Send a message via Yahoo to Phatwhippin_CRX
first, hit up www.crvtec.com and www.b20.net (if it hasnt shut down yet)
The B20z/b will fit in there with the same HAsport mount kit as a B16a. You can run a B18a/b intake manfiold. Only the B20b has that "giraffe" I.M, the B20z has a different design..... neither one would fit under the hood. You could use a B18c header with it, and I'll find out which ECU. I know there are ODB conversion harnesses out there...
1989 DOHC VTEC CRX Si
C'mon, it's only a Honduh...can't be fast!
I AM the Anti-Rice!
Swap info, Turbo tech, and naked chicks!
