Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
View Poll Results: how can i fix problem 2001 jetta 1.8t
fuel pressure problem? 0 0%
car shuts off 0 0%
2001 jetta 1.8t shuits off 0 0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Old 08-05-2005, 09:28 AM
mikedoggy mikedoggy is offline
car dies out when driving
i have 2001 1.8t jetta. when i'm driving car suddenly shuts off, i'll put in neutral start up again,and car runs fine this usually happens when its hot out, or once a day i took it to dealer and they replaced fuel pump relay but car still the same,only difference is that the engine light doesn't come on after i start back up when it dies out i've changed fuel filter spark plugs already, duno if its something with the fuel was thinking of putting new fuel pressure regulator.HAS ANYONE ELSE HAD THIS PROBLEM? MIKE FROM CHICAGO
Old 08-08-2005, 12:12 PM
98R/TDailyDriver's Avatar
98R/TDailyDriver 98R/TDailyDriver is offline
Send a message via AIM to 98R/TDailyDriver Send a message via MSN to 98R/TDailyDriver Send a message via Yahoo to 98R/TDailyDriver
Re: car dies out when driving
They will probably do the fuel pump next for an amazingly low bazillion dollars!
Old 08-08-2005, 09:38 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Cars just dont "shut off". They do die though, like when an alternator takes a dump and cant supply enough voltage to keep the car running.
When does your car "shut off"
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
