Old 08-05-2005, 08:26 AM
JoshBarber JoshBarber is offline
Question Delayed Starting (already searched)
So far the best info I've found was to replace the fuel filter, which I'll definately do first....but I was wondering if anyone else had experience or reccommendations.
The problem seems like its gotten a little worse over time (as in, the delay seems to have gotten longer). I've tried to pay attention to all conditions when it occurs, and havent really seen any difference unless the car was recently running (where it usually starts on the first attempt)
I'll turn the key for the first time, and it'll sound like its gonna start but doesnt. As I said, the delay time seems to have gotten longer before it actually starts. But it almost ALWAYS starts on the second attempt.
Any common causes for this?
Old 08-05-2005, 11:10 AM
drdd's Avatar
drdd drdd is offline
Re: Delayed Starting (already searched)
yeah, change your fuel filter if its due
also, check fuel pressure
check battery voltage (with ignition on, engine off - and again with engine running)
do you hear the fuel pump prime when you turn the key/
Old 08-05-2005, 11:15 AM
Re: Re: Delayed Starting (already searched)
yes, I hear the fuel pump...noisey as most are.
voltage is fine. is it easy to check the fuel pressure? or should I bring it somewhere?
I changed my fuel filter approx. 6,000 miles ago.
Old 08-05-2005, 11:26 AM
drdd's Avatar
Re: Re: Re: Delayed Starting (already searched)
What year truck do you have?
Do you have a Haynes or Chiltons manual. It will tell you how to check the fuel pressure. Its a little different depending on the year. Either way, you need a fuel pressure tester (about $40 from Autozone). You might even be even to do a rent-a-tool at Autozone.
What exactly is the battery voltage?
Old 08-05-2005, 11:29 AM
Re: Re: Re: Re: Delayed Starting (already searched)
1998 Chevy Blazer LT
I don't know, I didnt check voltage, my father did it when I wasnt around. Yes I have a Chiltons or Haynes whatever manual it is.
Old 08-05-2005, 12:42 PM
RedLT's Avatar
RedLT RedLT is offline
Quick question, when you try to start it does it turn over fine and just won't start like if you're out of gas or does it kinda start slugish and slow like you have no battery power?
Red 1995 Chevy Blazer 4X4
Check it out.
http://www.cardomain.com/ride/2071240
MODs
Brush Guard 2/20/05
Bigger tires 3/15/05
Flowmasters 6/18/05
Minor Paint work 2005
Upcomming
6 inch lift 0-6 months
Swampers 0-6 months
Dual Flowmaster Exaust 6-12 months
Old 08-05-2005, 12:46 PM
turns over fine, but won't start like Im out of gas.
sounds like theres plenty of crank power
Old 08-05-2005, 04:11 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
yip, AC Delco fuel filter would install fine.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-05-2005, 07:20 PM
I JUST replaced it 6,000 miles ago as I said. Why would it already be clogged
Old 08-06-2005, 12:51 AM
BlazerLT's Avatar
AF -Advisor
Yea, change it again.
Also, are you allowing the pump to prime before starting it.
Hold the key on the first position for two seconds so the pump can prime the system and then start it.
Old 08-08-2005, 02:45 PM
seems to start quicker when I wait till the fuel pump buzz stops and it's been primed. any idea why the change from before, when I could just start it without waiting the extra couple of seconds for it to prime?
Old 08-08-2005, 02:49 PM
BlazerLT's Avatar
AF -Advisor
Fuel filter is clogged again or your pump is weak.
Also, check your battery, if it is almost dead or dying, it can cause this too.
Old 08-08-2005, 03:10 PM
riccbhard riccbhard is offline
Not trying to intrude on this thread; but on my aunt's 98 Blazer; it starts perfect every time (no waiting) however if you just turn the key to the on position without starting; you can hear the fuel pump make a noisy buzz. It was checked and they said that the last person that put a pump on it forgot a ring somewhere; but it would be fine. I just wanted to ask if this would hurt anything. We've had it for over a year now with no problems
(Ahem, except the alternator dying)
Old 08-08-2005, 03:19 PM
BlazerLT's Avatar
AF -Advisor
That noise is normal.
That is the fuel pump priming the system.
Old 08-09-2005, 09:03 AM
replaced the fuel filter last night. no change in start time.
Im assuming the pump must be getting weak.
