Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 08-05-2005, 07:47 AM
jgj10 jgj10 is offline
2000 Trooper Surges / Stumbles
Hello all,
I have a strange problem with my Trooper. First some background:
2000 Trooper
95K miles
Two wheel drive
Mine has the oil consumption issue but I just live with it.
Here is the problem, intermittently typically during low RPM high gear (lugging) the car feels like its stumbles (rpm surges slightly). It may happen as little as once a day or a lot. It almost feels like something is bumping it from behind. I have tried to isolate it to time/temp/weather but there is no consistency. At cruise its fine. At first I thought it was the transmission slipping/shifting but now I’m leaning toward the engine.
Here’s the thing – no CEL or Transmission light. Otherwise it runs great and gets 20 MPG on the highway.
Any ideas?
Old 08-05-2005, 09:27 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 2000 Trooper Surges / Stumbles
Have you ever had the intake manifold gasket changed out?
see the FAQ's for more details.
if that is the problem and you are the orginal owner Isuzu will replace it for free.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-05-2005, 11:15 AM
rodeo02 rodeo02 is offline
No doubt. Sure sounds like the IMG. Try a search for "intake manifold gasket" or "IMG". You are probably due for a good EGR system cleaning on your 2000 as well. EGR typically kicks on hard @ low RPM hywy speeds. Check Ryan's FAQ's for IMG and EGR.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 08-05-2005, 11:38 AM
Guys thanks for the info.
I have never had the gasket replaced and I am the second owner so no warranty. Is there a way to verify the gasket is leaking -- visual or otherwise?
I try and keep the EGR tube clean thru the mouth of the throttle body and from up top on when removing the EGR. Although I don't know how good of a job I'm doing!
Thanks in advance.
