Go Back   Automotive Forums Car Chat > Buick > Century
Old 08-05-2005, 07:36 AM
gtmarko gtmarko is offline
Send a message via AIM to gtmarko
runs hot,idle dosen`t kick down,tranny
hello i have a 1994 buick century with a 3.1, the car temp gets hot and then the idle won`t kick down,also the car won`t shift into higher gear around 40 mph.so i shut it off for a hour and then everything ok .then it`ll act up again,i replaced the thermostat and lubed up the throttle linkage. any ideas please.
Old 08-05-2005, 10:31 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: runs hot,idle dosen`t kick down,tranny
These cars trannys are electrical. I would check the grounds. I have a 97 Lesable which had a bad ground by the battery on the fender well. It was causing all sorts of malfunctions to the point of stalling. With the age of your car I would look for something like this. Is your cooling fan running?
Dan
Old 08-08-2005, 03:47 AM
hello do you think it`s a sensor or is the head gasket golng, what get`s me is that the throttle doesn`t kick down until you let the car cool down
Old 08-10-2005, 06:09 AM
cleaned throttle body, but still overheats
Old 08-10-2005, 06:10 AM
cleaned throttle body,but still over heats any ideas?
