Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 08-05-2005, 04:29 AM
ash91si ash91si is offline
kill switch
I just got my civic stolen and now I have another one I have a 91 si hatch I want to install a hidden kill switch on the ingnition line so that no ass hole can have my car. Has anyone done this to there car or have any idea of how to I already have the switch and spot I am going to put it but wanted to know what you all thought.
word
Old 08-28-2005, 04:16 PM
crazi-85crx's Avatar
crazi-85crx crazi-85crx is offline
Re: kill switch
i'm about to do the same. you'll need some 12gauge wire, some Male and Female connectors, and a hiding place. cut into the power wire for the ignition and wire in your switch. it should work. try NOT to put the switch under the hood, dash, or in the glove box. because those are too obvious.
Old 08-28-2005, 05:39 PM
97integrals's Avatar
97integrals 97integrals is offline
I have done this in my integra, but instead of the ignition I have two switches (might be a little overkill) that kill the fuel pump. It has worked very well; there have been two unsuccessful attempts by thieves to steal the car since I installed the switches. I do, however, have a clutch lock so the switches cannot be given all the credit, but they make me sleep better at night.
Old 08-29-2005, 07:31 PM
dagoEF's Avatar
dagoEF dagoEF is offline
Re: kill switch
I've done one to fuel pump as well on my 90 hatch, works great. At first I would forget about it even
Old 08-30-2005, 03:02 AM
Re: kill switch
check these out, they majorly helped me out. i'm starting tomorrow.
how-tos:
http://members.cox.net/shaundrake/al...AlarmMods.html
http://www.jdmuniverse.com/forums/sh...threadid=20052
wiring:
http://www.bulldogsecurity.com/diagrams/diagrams.htm
Old 09-01-2005, 02:23 AM
BullShifter's Avatar
Re: Re: kill switch
I find it easiest to use the NEGATIVE coil wire. All you do is loop through a single pole METAL switch. It's basically like a light switch. Run the negative coil wire to the switch and a wire from the switch back to the coil. Simple, 5 min your done.
Old 09-01-2005, 11:51 AM
Re: kill switch
do you have a pic? here's mine...
... i hooked it up to the 10ga black/yellow wire coming out of the starter.
Old 09-03-2005, 09:28 PM
Geeko Geeko is offline
Send a message via ICQ to Geeko
Re: kill switch
This Article, in bold and hilighted at the beginning of this subsection, has a very nice guide. I'm surprised you didn't find it before.
BD (Before Deer): Clean... Very Clean.
AD (After Deer): Nascar Ready.
Go Baby Go.
Old 09-04-2005, 10:01 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Re: kill switch
+2 on the starter.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 09-05-2005, 12:49 AM
Re: Re: Re: kill switch
Originally Posted by superbluecivicsi
+2 on the starter.
?, well i ran the 10ga starter wire into the relay then ran some 14ga from the relay to my switch and a ground.
