Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 08-05-2005, 04:25 AM
ash91si ash91si is offline
speedometer broke?
Ok I was driving my hatch and the speedometer stoped working couple min later my check engine came on I checked my manual and read the light code the ecu makes and the ecu said that is is the speed sensor. I cant seem to find where that is or if there even is one. I want to fix this so that stupid light turns off can anyone help me on this i would appreciate it thanks
ash
Old 08-05-2005, 12:15 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: speedometer broke?
the vss (vehicle speed sensor) is located on your tranny.
Old 04-24-2009, 10:39 PM
t3h_roJo t3h_roJo is offline
Send a message via AIM to t3h_roJo
im having this problem with my speedometer as well, but i have the ABS light instead of the check engine light, and a mechanic i know personally said its most likely the VSS. But could the ABS light still be due to a malfunctioning VSS? i ordered it today and will go pick it up tomorow, any tips on how to change that bad bear?
Old 04-27-2009, 07:04 PM
big tex84's Avatar
big tex84 big tex84 is offline
its easy, unhook the old one, remove it from the tranny put the new one in, plug it back up, un hook your battery for about 10 seconds, your good.
Finally getting my swap done, Thought I would be relieved and satisfied, now I just wanna spend money on other car parts, WHERE DOES THE MADNESS END!!!!
