Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 08-05-2005, 01:26 AM
guffeyscavaliers guffeyscavaliers is offline
Question 97 Z-24 engine swap to cobalt engine
we would like to know, if we can do an engine swap from a 2005 cobalt supercharged engine into a 97 Z-24, using the wiring harness and computer too.
Old 08-06-2005, 09:48 AM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: 97 Z-24 engine swap to cobalt engine
it can be done, but dont expect it to be a direct swap
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 08-15-2005, 01:38 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
It won't be easy, no motor swap is, LOL!
I would keep the LD9 and get a small (4-6psi) turbo setup.
The Cobalt SS is destroked to 2.0, your Z has a 2.4 DOHC and they take well to turbo.
You could even upgrade your internals (crank, rods, pistons, valve springs, cams, etc.) and have a medium turbo (7-14psi), or larger with more mods, for less dough than it would cost to swap the Cobalt motor.
Odometer: 223259 & still running like a horse!
Rockin' to: Dream Theater, Queensryche, Symphony X, and Pagan's Mind. Check them out!
The "radio groups" these days have lost creativity and skill. It's the same thing for five minutes.
Old 08-15-2005, 06:53 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Or you could buy the Supercharger for the LD9 which is build by GM
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 08-29-2005, 12:56 PM
Re: Re: 97 Z-24 engine swap to cobalt engine
^Like -Jayson-! You can see that beautiful GM SC mated to the LD9 in his sig.
I would almost bet that Jayson's GM Supercharged 2.4 is just as fast, if not faster, than the Cobalt SS.
Old 08-30-2005, 02:17 AM
97grandamld9 97grandamld9 is offline
Banned
But the LSJ is built for boost, i have heard it can handle up to 15psi maybe more, a stock LD9 is going to take 10-12psi max then go boom. Although you will have trouble finding an LSJ and when you do expect to pay around 5 grand for a long block then you will need the wiring harness and PCM to make the motor work and so on. It will e expensive and you might just be better off going the 3800sc route.
But like people said, you should just boost the stock motor (unless your looking to do something no1 has done yet) You could build a decent boosted LD9 for around 5k
Old 08-30-2005, 09:39 AM
-Jayson-'s Avatar
i run the same times as a cobalt SS S/C. Also think of where your going to get the 2.0 S/C engine, your gonna have to buy it directly from GM. I doubt there are many wrecked engines in the junk yard. ANd just cause the 2.0 S/C runs higher boost doesnt make it more poweful. I guarantee you, 10-12 PSI on an Ld9 will put out more power than 15 PSI on the 2.0 S/C.
2009 Ninja 650 R
stock for now...
Old 08-30-2005, 10:25 AM
As the old saying goes,
THERE'S NO REPLACEMENT FOR DISPLACEMENT
