Old 08-04-2005, 10:53 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Code 4.. DOHC ZC
hey, my friends ZC is throwing a code 4 (crank angle sensor) she has a dohc ZC automatic
any ideas on what might be wrong? she already replaced the dizzy with a brand new one
Old 08-04-2005, 11:59 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
the car drives fine? could be a loose connection somewhere. check the infamous 2 white wires. did you reset the ECU? check for an open or short in the orange and white wires from ECU pins B10 & B12 to the distributor. measure resistance between pins B10 & B12 at the ECU. It should be 350-550 ohms. if not, you have open in one of the wires somewhere. if the resistance measures okay, check continuity between body ground and B10 - if you have continuity, you have a short somewhere in the orange wire. if all this shit checks out alright, check the cam timing. does the engine idle nice and smooth? if the injector impulses are off, it could possibly cause the code i guess, but thats pretty unlikely.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 08-05-2005, 07:19 AM
1PhatCX's Avatar
Re: Code 4.. DOHC ZC
not sure if the car drives fine or not, just my friend e-mailed me and told me about how her cars throwing a code 4 again even after she replaced the dizzy with a brand new unit. shes going away for the weekend so i wont be able to get any extra info about what its doing untill she comes back
Old 08-05-2005, 12:10 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
Crank angle has nothing to do with the Distributor... but My ZC was flashing that code for like 6 months after I changed the head gasket on the car... not sure why. the car rand fine, and never caused any problems... well t'il I blew up the transmission but that's a whole other story.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 08-05-2005, 12:23 PM
1PhatCX's Avatar
i thought the crank angle sensor was in the distributor???
Old 08-05-2005, 03:59 PM
Kunundrum's Avatar
Cam angle sensor Typicaly is in Distributor (or on the exhaust cam on the DOHC ZC) ... I'm not sure where the Crank angle sensor is located... I kinda figured near the crank.
I could be wrong though....
Old 08-05-2005, 04:39 PM
1PhatCX's Avatar
Re: Re: Code 4.. DOHC ZC
ok, well i'll check into this some more then. keep the ideas flowin guys
thanx for the useless input k-drum hehe j/p
Old 08-05-2005, 05:45 PM
g-ride-si's Avatar
g-ride-si g-ride-si is offline
i was told crank angle sensor was in the dizzy like stated above the white wires...im throwin the same code with my b18
G-RiDE-SI
