Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-04-2005, 10:22 PM
rs97eclipse1695's Avatar
rs97eclipse1695 rs97eclipse1695 is offline
Send a message via AIM to rs97eclipse1695
Question potential to boost my rs...need specifics...help!
whats up guys...and before you post saying search first....i know theres a sticky on this...but i need specifics because my parents arent crazy about the idea of turboing my car...but it should be easier to convince them to do this than to sell and buy a gst/x...not to mention....there arent any around here...so help me out...esp. you jake...because i know you know what you are talking about and i really think this is my only way to have a turbo so help out a fellow dsmer
anyways...heres what i know i need so far
Injectors
(450)
Turbo - found a t25 for 100 shipped to me
Manifold
down pipe
blow off valve - found this and smic locally for $75
Intercoolerintercooler piping
Datalogger
(sacf II) - will this work for a 420a?
Gauges w/ gauge pillar
(boost, air/fuel, egt)
boost controller
i know this isnt all so please add/corect my list and post input
also ..is my rs going to be just as relaible now as it was before turboing it...in other words...am i more likly to have problems out of my car if i turbo it??
2008 Eclipse GT
-Sun Sound and Leather Package
-BONE stock
1997 Mitsubishi Eclipse RS
-Cold Air with K&N
-Stainless 4-2-1 Header
-2.5" Catback
http://www.cardomain.com/ride/3012565
Old 08-06-2005, 12:29 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Thats pretty much all that you need. You should also pick up some vacuum lines(a crap load) some t-fittings, an oil drain line, and you will most likely find out what else youll be missing when you are doing the install. Good luck.
P.S. Im not sure but you might also need a new fuel pump.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 08-06-2005, 05:28 PM
tsi4444 tsi4444 is offline
dont forget oil and coolant lines
97 TSI AWD
Apexi N1
RRE Downpipe w/test pipe, K&N FIPK, RRE lightened flywheel, ACT 2600, New short block installed due to crankwalk,autometer sport comp boost gauge,type-s bov, brode uicp, Johnny race car fmic with custom piping, evo 3 16g
Soon to be purchased: DSM link, injectors, fuel pump
Old 08-07-2005, 01:30 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Your car will not be even close to as reliable as it is now. Problems will be a part of the game. There is some give and take in a turbo relationship. Hope it all works out for you anyway.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-07-2005, 01:32 AM
ted_ex's Avatar
ted_ex ted_ex is offline
Re: boost in an rs...need specifics
The more power you get out of a car the more likely it is to have problems. If it's done correctly the car can still retain it's reliability to an extent, but more power means more pressure and heat and that means more wear. And the AFC will work on pretty much any car.
tedX
I'm>everything
