Old 04-30-2002, 01:26 PM
JRuner1 JRuner1 is offline
Send a message via AIM to JRuner1
Please explain this JL sub to me!!!
i was thinking about getting 2 JL w6 subs. but then i started hearing that because of the ohm level or something that it would be balanced to get 3. what does that mean? and would it not sound right if i got just 2? cause 3 subs is just too heavy for my little stock civic engine. if it doesn't sound right then what sub is comparable to it.... autobahn, phoenix gold, crystal mobie? thanks for the help!!
Johnnie
Old 04-30-2002, 03:24 PM
92Accord92 92Accord92 is offline
Send a message via AIM to 92Accord92
I'm not sure why it is that way, I know that the JL Audio 10W-6 has a Dual 6 ohm voice coil, and I have 3 of them wired in series at a 3 ohm load.
If your going JL Audio, depending on whether your a bass head or not. You'll get enuff base with just one, only point in having 3 is more bass. Definatly not worth it, if your not going for SPL.
92Accord92
Old 04-30-2002, 05:01 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
many people are suggesting getting 3 JL W6 because since when you wire all three in parallel, you will get a 1ohm load. if you get two, it will present the amp a 1.5 load. usually company will rate the amp at 1ohm, 2ohm, 4ohm, 8ohm, etc. so if you're planning to get 2 subs, make sure you know how much power the amp puts out at 1.5ohm. also, be sure the amp are stable to 1.5ohm or lower. if it's stable only to 2ohm, DON'T TRY IT! most likely the amp will overheat and fry. maybe if you put some kind of fan on it then it'll have a better chance of surviving. to calculate the ohm the amp will see, simply use this equation:
Ohm per sub = total Ohm
number of subs
say you have 2 subs. each one is a single voice coil and 4ohm. so take the "4" (ohm) and divide it by "2" (total amount of subs) and that will give you 2 as your answer. you're amp will see a 2ohm load with 2 SVC 4ohm subs
PS. i got bored so i just typed all these down :finger:
I love them sub wufers
Old 04-30-2002, 07:39 PM
CXHatchback's Avatar
CXHatchback CXHatchback is offline
Send a message via ICQ to CXHatchback Send a message via AIM to CXHatchback
OR even easier, buy JL Amps to go along with just the two subs, and you won't have to worry about the ohm loads as long as they're within 1.5-8 ohms. I've got two of them, they're killer.
Old 04-30-2002, 08:54 PM
rendog24's Avatar
rendog24 rendog24 is offline
fuck the w6 man. get the w7's. yeah!
or some audiobahn alums.
"Don't touch what you can't grab, End up with two backhands, Put anthrax on a tampax, and slap you 'til you can't stand" - Eminem
Old 05-01-2002, 01:52 AM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
W7 is GH3Y! :finger4:
Mearly a toy...
MA Audio Hard Kore Series
Patented Dies-Cast Chrome Plated Basket
Four 1.5-Ohm High Temp Aluminum Voice Coils
Patented Thermo-Cooling Motor Structure
Over Sized Mounting Holes for Firm Support
Patented Vertical Cooling Fins
360 oz. Triple Stacked Strontium Magnets
Slot Vented Motor Structure
Glass Fiber Cone for Superior Strength
High Profile Triple Treated Foam Surround
Chrome Plated Push Terminals
Flat Wire Copper Voice Coil
Multi-Braided Insulated Tensile Lead
5,000 Watts Rms
10,000 Watts Max
3” Bobbin Voice Coil Structure
Sensitivity: 89.3 dB @ 1w/1m
Frequency Response: 30 Hz-500 Hz
http://www.maaudio.com/productcatalog.cfm?class=263
AF's Official Asshole
RIP AUNIE
Old 05-01-2002, 01:57 AM
sparq's Avatar
AF Premium User
Two DUAL 6 ohm voice coil subs =
TWO 3 ohm loads
TWO 12 ohm loads (but why?)
SINGLE 1.5 ohm load
Three DUAL 6 ohm voice coil subs =
THREE 3 ohm loads (but why?)
ONE 4 ohm load (This is why 3 is recommended)
ONE 1 ohm load (This is why 3 is recommended)
By using three, you allow for 4 ohm or 1 ohm loads -- which are STANDARD amp type loads... TWO running STEREO would also be good, heres an example
Amp puts out...
200 x 2 @ 4 ohms RMS
400 x 2 @ 2 ohms RMS
Running TWO of the subs @ 3 ohms EACH you would get :
300 x 2 @ 3 ohms RMS
Take the differance between them, and divide it... and thats your 3 ohm power. Simple!
RIP AUNIE
