Old 08-04-2005, 07:17 PM
omaro86 omaro86 is offline
Oil/ lifter tick
Iv always had lifter tick on my car when the motor was cold, but these past few weeks its been over 90 alot. Iv notived that the lifters are alot louder now when the motor is warm. I was told thats because I'm using to light an oil. (10w30) So i was told 2 things.
1. switch to synthetic
2. use higher weight oil
my question is should I switch to synthetic?? the car has 85k on it...and what oil would be good for right now driving in 90 degree+ heat all the time?? 10w40 or 15w50?
Old 08-05-2005, 11:57 AM
2old 2old is offline
Re: Oil/ lifter tick
Use synthetic...
The problems of switching to synthetic much gone away. Also just use 10W30. Moving to a thicker old will only agrivate the problem.
The lifter tick is because the hydraulic lash adjuster oil inlet is clogged. Changing to synthetic will help because they tend to have more detergents in them then mineral oils and I would be more agressive with oil changes (3000 miles?) until the tick goes away.
Old 08-05-2005, 02:20 PM
unicyclemidget11 unicyclemidget11 is offline
could you give me some more info on the hydraulic lash adjuster oil inlet being clogged? How could i fix this?
Old 08-05-2005, 03:15 PM
About 1/3rd down this page:
http://www.3sxperformance.com/engine-upper.asp
The early style lash adjustors had a small inlet that gets clogged with "oil sludge" pretty quickly. You can clean it using some of the "engine cleaners" or by frequent oil changes or you can change out the lash adjusters to the "newer style" ones.
I am too lazy to change them out, so I just use synthetic and change my oil every 3000 miles and the tick doesn't happen.
Old 08-06-2005, 10:35 AM
AutostradaVR4 AutostradaVR4 is offline
Same here. Ive been using Mobil 1 10W30 and havnt had a problem yet...90kmi
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 08-06-2005, 11:11 AM
Re: Re: Oil/ lifter tick
Originally Posted by 2old
Use synthetic...
Alright, I'm going to do it in a few minutes. One more question though, is in really neccesarry the first oil change after switching to synthetic to change it out 1500-2000 miles instead of 3000?
Old 08-06-2005, 12:03 PM
Re: Re: Re: Oil/ lifter tick
I haven't heard of that one... I don't see why you would need to... Synthetic will mix with mineral oil perfectly well (you basically end up with a semi-synthetic blend) and if you drain the oil and change the oil filter the most residual oil you could possibly have in the engine is 1/2 liter so it wouldn't dilute the fresh 4 liters you put in by much.
Basically what you are waiting for is, after you change the oil the tick should go away... If it comes back before you reach 3000 miles change the oil then, if it doesn't come back before 3000 miles change your oil at 3000 miles.
Old 08-06-2005, 12:09 PM
I also heard that when you switch to synthetic, all the "gunk deposits" from the natural oil are broken free by the detergents, so you should do another change shortly afterward.
Formerly BlinkRA182
Old 08-06-2005, 12:22 PM
I guess it depends if you need a "hard number" to do the oil change or not... You may or may not need the oil change at 1800 miles depending on how "gunked up" your engine is... It's probably better to listen for lifter tick because it could start ticking before 1800 miles or it may not tick at all...
But I may just trust my oil filter too much.
Old 08-06-2005, 02:20 PM
Alright, I just changed it with Quaker state Q 10w30.... I'm probably going to change it again at about 2000 miles to check, it can't hurt. I'll post up in a day or two to let you guys see if the change helped at all, if your curious.
Old 08-09-2005, 08:24 PM
Alright, it's been 3 days and the tick didn't get ANY better after switching to sythentic.... Is it just time for 3rd gen lifters?? Or should I switch to a thicker oil? And how hard would the lifters be to install???
Thanks.
Old 08-10-2005, 11:35 AM
Thanks.
Ugh... I guess as some point the drain is clogged enough that draino doesn't work anymore...
It sounds like the lash adjusters are too clogged to even let fresh oil pass through... You might trying a LIGHTER oil (5w30?) or lighten your current oil with a... *gasp* oil additive (I don't like it either but I am starting to run out of ideas) which would make it easier for the oil to pass through small passages, but it sounds like you might need to physically clean the oil passages (in which case you might as well change to 3rd gen lifters since you are there already).
Someone has a article on the net on changing the lash adjustors using a crow bar to lift the rockers which is easier then disassembling the valvetrain (many parts and they HAVE to be torqued to spec) but it's still tedious with 24 lash adjusters. I will try and google it and get back to you.
Old 08-10-2005, 11:48 AM
Just go to the FAQ in this forum or google "stealth lifter tick" if you want information on changing the lash adjustors (http://johnmonnin.netfirms.com/) is a good place to start.
Old 08-11-2005, 04:53 PM
Thank you!... good link, I'm pretty sure I'm going to just get 3rd gen lifters.
Old 08-12-2005, 12:42 AM
exterra3000gtsl exterra3000gtsl is offline
just wait a while...got mine with 75k on the clock.. had the same problem, put sinthethyc royal purple on it and after about 4 oil changes you the tick is very very minimal...when i got the damn thing was scaring me i thought something was loose inside... sure it still does it everynow and then but nothing that calls for attention
