Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 08-04-2005, 06:50 PM
tiger529 tiger529 is offline
Send a message via AIM to tiger529
'74... needing some help
ok, so i have this 74 SS hatch that i picked up for about $1500...... ran awesome, hasnt even rolled over 100k yet, and i got the original bill of sell from the chevy dealer, the owner was the original buyer of the car.
ok, so i pulled it up into my yard one day to was it, when i was done i went to start it up and nothing........ no power, nothing.
my dad and myself have been messing w/ it for months now. checked everything we could think of: starter, wires, fuses, etc... so im stuck and dont kno what to do.
only mods to the car are cam, carb jets have been bored out, exhaust(wayyyyyy out of date tho), and had AC Delco electronic ignition put in after the car was purchased.
small block 350- original, is the engine im working with.
any help would be much appreciated.
thanks
Old 08-04-2005, 07:36 PM
lloyd tucker lloyd tucker is offline
Re: '74... needing some help
Check the "fusable link" that goes to the starter. It looks like a connector inline with the wire. I had that problem once with a Malibu. It just died with no warning. If that's not the problem, I can't help. Bad news is you probably got a short somewhere & the water found it when you washed it.
LLoyd
thanks
Old 08-05-2005, 04:54 AM
NOVA71's Avatar
NOVA71 NOVA71 is offline
Yes check the fusible link.Their should be one coming off the battery that goes to a junction on the rad support beside the battery. check that maybe where it bolts came loose. I had this happen to my Nova before. All of a sudden you'd have no power to anything. After a quick check, all it was was a loose bolt for that fusible link.
Current Rides:
1971 Nova
2004 Tracker
2013 Sonic
Past Rides:
2007 G5
1984 Firebird
2000 Jimmy
1994 Jimmy
1990 Tracker
1985 Jimmy
Old 08-05-2005, 05:54 PM
fusible link was one of the first things i replaced. wasnt it..... wish it was a simple as that :/
Old 11-16-2005, 08:22 PM
spidermann59 spidermann59 is offline
Hey 529, You seem very through, did you try by- passing the ignition switch?
or battery cable, may be the previous owner added a secret switch? Let us know what you found O.K. ?
Never Give Up!!
Old 11-16-2005, 09:31 PM
Re: Re: '74... needing some help
already tried that. think i have found the issue. the group of wires that run from the fuse box at the firewall are giving me bad readings from the tester, gonna replace those and go from there.
Thanks for all the input guys.
