Old 08-04-2005, 06:52 PM
blue92civic blue92civic is offline
Send a message via AIM to blue92civic Send a message via Yahoo to blue92civic
over cammed?
ok my 92civic hatch has a 91 ls swap with a 98 ls head. i put in crower cams/spring/retainers andf all my car does it bogg. she has no sac anymore and wont fire on 2 cyclinders. i need some advise or help to why this is thanks
Old 08-04-2005, 07:30 PM
ZedEx's Avatar
ZedEx ZedEx is offline
GO-FIGHT-KILL!
Send a message via AIM to ZedEx
Re: over cammed?
... So she has no sac? Isn't that normal
What Crower Camshafts did you put in, what Valvetrain, etc. We need a few more details.
-Wes
-2000 PY Acura Integra Type-R #686 - WhoRe
-1997 EGP Honda Prelude Type-SH - Daily driver
R.I.P Hypsi87:Andy Filson
Old 08-04-2005, 07:48 PM
Talking Re: Re: over cammed?
i put in stage 2 crower cams/ crower spring/ crower retainers and my cold air intake/ apexi ni exhaust/ dc sport headers
everything else is stock
and yeah she isnt supposed to have a sac
Old 08-04-2005, 08:29 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: over cammed?
If it's not firing on 2 cylinders, then that's the problem. Check the plugs and make sure the plug wires are hooked up to the right place on the distributor. What ECU are you using (obd1 or obd2), what distributor are you using (obd1 or obd2), if the distributor is obd2 then what harness are you using (aka: is it wired correctly), was this swap done and working correctly before you added the cams and valvetrain, have you checked the timing?
Old 08-04-2005, 10:49 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
dont forget to check spark and fuel to cylinder two.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 08-05-2005, 01:35 PM
Re: Re: Re: over cammed?
im running the stock cap n rotor and the swap was running fine until we put in the cams. i called the god mechanic (my dad) and he said it sounds like i bend a vavle so im gonna pull off the head and see if the vavles are messed up becuz i dont think im getting compression to 2 of the cynlinders. i got the cams in a 98 head which the kid before me threw a rod so i think its just a vavle problem
