Old 04-30-2002, 11:59 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
axle problem
Hey sup . I'm tryin to pull off my stock axle to put my new integra axle. I can't get it my stock ones off. I tried that axle flange puller, i tried hammering it out and still not budging.Can anyone help me please??
Old 04-30-2002, 01:27 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
its not coming out of the tranny or the hub?
I usually just use a big ass screwdriver and pry it out from the tranny..they're held in w/ snap clips and are kinda hard sometime...try rotating it back and forth as you pry and pull...
SOLD!
Old 04-30-2002, 01:40 PM
mellowboy's Avatar
its from the hub. Its in there pretty damn good and its becoming a pain!
Old 04-30-2002, 04:37 PM
EightOhOne's Avatar
EightOhOne EightOhOne is offline
did you separate the lower ball joint/lower control arm? If you do that, your rotor/hub will swing out far enough that its easy as hell to take out
Old 04-30-2002, 10:57 PM
mellowboy's Avatar
Yeh i did all that and it still wouldn't budge! I'm gonna have to keep trying i guess?
Old 05-01-2002, 07:18 AM
ricodemus ricodemus is offline
cant you just beat the shit out of the back of the hub til it comes off?
I'm a lonely male who'll settle for any phony in a ponytail - MCPB
The b16 is in and running strong
Old 05-01-2002, 08:56 AM
mellowboy's Avatar
I don't know if that would work? I'll give it a try.
Old 05-01-2002, 01:44 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Lightbulb
Hold up dude...don't beat the shit out of anything. you'll end up breaking something else...
Take a ball peen hammer (the kind with one side of the hammer head is round) and set the round part on the end of the axle...Then take another regular hammer, or a short handled sledge (8 lbs. or so) and whack the ball-peen hammer....that keeps the axle from getting damaged (or the hub) and should provide the right whack to knock it loose. Also, spray some WD-40 or brake cleaner or something all up in the splines and stuff to loosen the thing a little before you bang it. In addition, you can leave the nut on the axle (just a few turns by hand) to protect the threads as you hit it. But the ball-peen hammer usually works pretty well.
Good Luck. :smoka:
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 05-01-2002, 04:05 PM
RedRocketGSR's Avatar
RedRocketGSR RedRocketGSR is offline
Send a message via AIM to RedRocketGSR
yea i like sastanley's idea. First i would spray it with WD-40 and then i would take a screwdriver or something like it and a hammer and just knock it loose from the outside. If you just work at it a little, it WILL come out.
95 Integra GS-R
[email protected]
Old 05-01-2002, 04:11 PM
mellowboy's Avatar
yeh i'll try everybodies ideas.
Old 05-05-2002, 11:46 AM
mellowboy's Avatar
Update
Hey sup guys. I got the axles off and i used the impact hammer. On the driver side it came out like it was nothing. On the passenger side it took awhile to get it out after we kept hitting it with the hammer. So after that we used the impact hammer to take it out and it came out fine. Just thought i'd let u guys know
