Old 04-30-2002, 11:43 AM
white rice white rice is offline
Send a message via AIM to white rice
Question how easy installing cambers & springs??
just wanna know if anyone has done-it-themself (installing front & rear cambers and springs on an 88-91 civic HB, and how easy it was.
Old 04-30-2002, 12:27 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
pretty easy..most can do it themselves...the only tricky part is taking the strut assembly apart, which can be pretty dangerous...there's a variety of ways to do this, only a few of which are safe.
as far as the camber kit...its pretty easy, just have to unbolt the upper control arm...cake.
SOLD!
Old 06-03-2002, 01:01 AM
PFCfutrell PFCfutrell is offline
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
I've allways done my own shocks and springs and have never needed any special tools except the one time. When I put on my Tokico's the tops of the stock shocks were rounded out so I had to grind them down, other than that it was cake. I didn't even need a spring compressor, all you need is a good socket set (air tools help) and the correct size hex-wrench for the top of the shock, that's about it. If you need details I could give you a step by step with pictures but it's pretty easy.
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
Old 06-03-2002, 02:06 AM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
ill make the request for that i got springs to install but no air tools or anything so that info would be very useful!
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 06-06-2002, 02:14 PM
jc836 jc836 is offline
A very important point here-if you have stock springs you will want to have them removed from the shocks with the proper tools-that means a real spring compressor. The options for this are really simple-rent one from Autozone (return it and get your money back_that is their deal BTW) or you can pay a shop to take the assembly apart and put the new springs on. Then you go home and reinstall the assemblies.
For the Camber kits-they are generally very easy to do. Look at the drawings or under the car to see where the stock mounting points are for the upper control arms. That is where you take it apart and rotate the control arm around and remove the stock pieces and replace them with the kits.
WARNING: Don't buy just any kit-get an alignment first to see how much adjustment you need.
Final thought-use a torque wrench on ALL of the bolts. I had the ocassion of finding my Prelude going down the road with a control arm bolt that was not fully tightened-not a lot of fun.
