I was driving along today, taking my girlfriend out to lunch and something happened. I was probably doing 30mph or so in 4th gear... nice and easy... and then I noticed a few minutes later my CEL came on. I'm like "That's not good." I turned off the car when we got to the parking lot and turned it back on and the CEL was still on. But the car drove fine so I knew it wasn't anything huge. So I went home and did the ECU test and it gave me the code of 67. I looked that up on a site and it read:
"Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system" What does that mean? What's a catalyst? I was wondering if anyone has ever had this problem or has fixed it ever? What would you guys recommend doing? Thanks! |
Wait a minute... sorry, did some searching on Honda-tech. Apparently that means the cat is bad. So does that mean I have to go buy a new one? Or should I just upgrade? If so, what cat would you guys recommend?
1996 Honda Civic EX btw. |
Re: Code 67 Help!
reset ecu. if it comes back, then, your cat has crapped. more likely clogged. get a new oem one or go hi flo or test pipe.
hi flo and test pipe may still throw you a cel, so an o2 sim would be nice.
99 [email protected] psi si- I voted for the Terminator for Gov. 95 HB- B16a2- SC34@12psi WTB: USDM B16a2 or B16a3 complete short block. pm is the key. FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me. |
Yeah, I'll try to reset the ECU tomorrow. That's disconnecting the negative terminal for a few minutes right?
Anyways, I was thinking about the Skunk2 Testpipe. It already has an O2 Sensor bung on it so would that mean it would be functional without throwing a CEL? |
Ok, reset the ECU today and left it sit for a minute or two with the Negative terminal disconnected. Started her up and no CEL. Must have been just a bad code or something.
Thanks for the advice superbluecivicsi. |
