Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-04-2005, 11:38 AM
curtishall curtishall is offline
Send a message via MSN to curtishall
AC Clutch replacement?
My AC clutch is dead......... My current truck (with the dead AC clutch) is a '95 dodge ram 1500 4x4 (318). I have a '94 dodge ram 1500 4x2 (360) sitting in a field not being used. I know the ac clutch is good on the '94...can i swap this part out by myself? I'm very shade tree...i can do things if I have good directions .
Obviously I have to pop the belt and unbolt it. But it has two lines coming in which I assume are pressurized. Can I just unbolt these lines without some fancy skill or tool?
Thanks
Old 08-04-2005, 10:56 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: AC Clutch replacement?
I wouldn't advise disconnecting the A/C hoses off the old truck. You can swap clutches w/o disconnecting A/C hoses. Go to your local auto parts store and ask for a kit to pull the clutch off b/c it's pressed on and will have to be pulled off like a steering wheel puller. Other than disconnecting the drive belt, and the electrical connector, that's all you'll need to do to swap clutches, assuming that they are compatible, not 100% certain.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 08-05-2005, 03:56 AM
Posted by theFREAKnasty82 - 08-04-2005 at 08:56 PM
Sorry I guess I'm lost. What are you referring to as the clutch? Are you talking about the round circle that the belt sits on? If so just unbolt that and use the tool to pop it off? Will a new one pop on in it's place?
I was thinking about replacing the entire unit - am I wrong here?
Old 08-08-2005, 12:53 AM
the clutch is the part underneath the pulley. Actually, the pulley and the clutch are all one piece. It won't just pop off, it's pressed on to the nose of the compressor and you'll need to have a special puller to remove the clutch. Like I said, consult your local auto parts store, they probably can loan it out to you, or go somewhere like NationsRent and they probably would have it also, it's a specialty tool.
Old 08-08-2005, 08:31 AM
Re: Re: AC Clutch replacement?
Okay I understand how to take it off (i have to find one first - autozone only sells the compressor). How do I put the clutch on if I do find one?
Old 08-09-2005, 12:43 AM
the clutch can be pressed back on using that special tool; it allows the clutch to be pressed on and off the compressor. If you're buying a compressor from Autozone, I'm surprised one is not already installed from the factory, sounds odd to me.
Old 08-09-2005, 08:31 AM
I can buy a whole new compressor that comes with a clutch for $200+. I was hoping to find a clutch somewhere and save some cash
If i yanked the compressor i would have to figure out a way to store (or not store :P) the feron
