Old 08-04-2005, 10:10 AM
cjhenderson cjhenderson is offline
Exclamation all escort owners should know!
50% drop in fuel economy, no "check engine" light; engine hot, but heat gauge said everything is just fine. I read this forum, a lot of escorts are having symptoms of cronic overheating. Solution: IAC--Idle Air Control, runs about $50, what a differents! Easy visual check, this little guy is right on top of the engine, takes two bolts and a electric connector to evaluate. I took mine off and found that there is a spring inside that was really crudded up with carbon.
Old 08-04-2005, 11:09 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
I don't think the IAC has anything to do with fuel consumption or heat disappation. New one on me.
Nevada Tumbleweed
Old 08-04-2005, 03:44 PM
Bobbywolf Bobbywolf is offline
Re: all escort owners should know!
When my IAC was fouling up, I had stalling and idling issues, and maby some gas milage problems. I cleaned it out with a good amount of break cleaner and it worked right as rain again. Like you said, the spring and plunger was totally carboned/crudded up.
Old 08-05-2005, 12:08 PM
jeffescortlx jeffescortlx is offline
Send a message via AIM to jeffescortlx
The IAC (idel air control) valve has nothing to do with fuel consuption or engine temp. It's just a bypass of the throttle body plate so the ECU has control over the idle speed, so it stay's regulated with a change in engine load, like when you turn on the A/C.
If the IAC was bad, you'd either stall, or have a high idle.
I make slow Escorts less-slow.
My cardomain
