Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-30-2002, 09:59 AM
4g88civicS 4g88civicS is offline
Send a message via AIM to 4g88civicS
Vtec
We recently did a sohc vtec swap in my friend's crx. It was the celestial blue pearl on at the 4th gen meet. We arent quite sure if the vtec is kicking in. What is a surefire way to tell the it is defiently working?
Adam
Old 04-30-2002, 10:10 AM
ricodemus ricodemus is offline
If everything is hooked up right and the ecu is good, you would get a code if a sensor or the vtec solenoid was bad. If you arent getting a code, I'm supposing everything is ok and it might not be engaging due to insufficient oil pressure, coolant temp, or speed over 20mph. Try revving from under the hood while toggling +12v to the solenoid and see if there isnt a difference in sound. I've heard that the x-over isnt very noticable in the sohc, but if you're looking hard, you probably should pick it up. When we tried that test with my b16, it screamed when it got 12v to the solenoid. unfortunately my ecu doesnt want to make it work when it's supposed to .
I'm a lonely male who'll settle for any phony in a ponytail - MCPB
The b16 is in and running strong
Old 04-30-2002, 12:03 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...or try this, start out in second and just ride it all the way to redline...you should definitely hear it switch..if it doesnt, you'll also feel the power drop out above 5000 or so...
SOLD!
Old 04-30-2002, 09:15 PM
RedRocketGSR's Avatar
RedRocketGSR RedRocketGSR is offline
Send a message via AIM to RedRocketGSR
or if you wanted to have a VTEC light anyways then run the positive wire to the VTEC solenoid and just ground the negative wire. Drive around the block and when VTEC kicks in then the light should turn on. If the solenoid isnt getting power(no VTEC) then the light wont light up.
95 Integra GS-R
[email protected]
Old 04-30-2002, 11:39 PM
Phatwhippin_CRX Phatwhippin_CRX is offline
Send a message via ICQ to Phatwhippin_CRX Send a message via AIM to Phatwhippin_CRX Send a message via Yahoo to Phatwhippin_CRX
.....or just do it the easy way
Warm up the car, make sure it's got plenty of oil and find a highway.... @ 4800 RPMs or so, you WILL hear a QUIET change in pitch..... it's very subtle, but it is very audible if you know what to listen for....
1989 DOHC VTEC CRX Si
C'mon, it's only a Honduh...can't be fast!
I AM the Anti-Rice!
Swap info, Turbo tech, and naked chicks!
Old 04-22-2004, 04:02 AM
kingpinn's Avatar
kingpinn kingpinn is offline
Re: Vtec
get octane boster see if that helps
Old 04-22-2004, 07:33 AM
marked001's Avatar
Moderadur
Re: Vtec
hmm...also two years old.
SOLD!
Closed Thread
