Old 08-04-2005, 08:05 AM
justinsz8's Avatar
justinsz8 justinsz8 is offline
Question shifter sticking
i have a 97 trans am that the shifter is sticking in park. the only way to get it out is to take the console apart and manually move the lock down. my question is this, is this common? is there an easy fix? i read another post on here, but on that they told the guy to set the brake before parking on slopes. i live in kansas so there are no slopes. the bracket for the lock just isn't moving down far enough to disengage it. help!!!!
Old 08-04-2005, 09:00 AM
justinsz8's Avatar
Re: shifter sticking
Also, how do you get the shifter knob off, without breaking it????
Old 08-05-2005, 10:12 PM
95firebird 95firebird is offline
ya this is very common in what happened to mine was there as spring in side with this plastic thing I forgot what it was called but I broke so I had to replace that haven had a problem since to take it off there should be a pin on the front of the knob pop it out and it will come off
Old 08-06-2005, 10:24 AM
justinsz8's Avatar
alright, I'll check that out. thanks.
Old 08-08-2005, 12:23 PM
so did u get your shifter fixed
Old 08-08-2005, 02:17 PM
justinsz8's Avatar
I haven't had time to look at it yet. I am tonight after work, I'll update ya then.
Old 08-09-2005, 08:17 AM
justinsz8's Avatar
alright, i looked at it. it all came apart real easy just like you said. the plastic rod that goes from the handle down to that lock bracket, has about 2 to 3 mm broke off of the top of it, so it's not pushing that lever down far enough. guess i will have to buy a new one. thanks for your help!
Old 08-09-2005, 09:51 PM
Yup There Very Cheap And Snap All The Time And Your Welcome
