Old 08-04-2005, 05:22 AM
martikus martikus is offline
Send a message via Yahoo to martikus
Angry 92 camaro rs that won't stay running
ok guys, really need some help here. i have used this forum to help me with several things with my 92 camaro, so i know that i can trust the advice here. i am having a fuel problem, i have changed out the fuel pump, and both of the relays on the driver side firewall. now here lays the problem, i can be driving down the road and out of the blue, it stalls, there is no spit or sputter, just cuts out. when i try crank that car, the tbi is not getting gas, but there is gas going to it. is it possible that the tbi could be bad? any help will be greatful.
Old 08-04-2005, 10:00 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: 92 camaro rs that won't stay running
Is there a fuse that controls the injectors. Maybe a short in the VSS. Or a short in general.... Thats my only advice. Theres a strong chance that im way off and not even remotely correct and dont know what im saying but.....who knows... i may be on to something.....
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 08-04-2005, 01:36 PM
Topliss92RS Topliss92RS is offline
Does it start again after some time? I would chech for fuel lines getting hot and causing vapor lock. If the fuel heats up till it vaporizes, the TBI may not be siphoning the fuel it needs to inject. Also make sure that your grounds are good on the new relays. Rust/paint may be preventing good grounding.
Old 08-04-2005, 08:24 PM
[i have checked the fuses, and everything else, both relays are new. it would run after a while, but now it will not start at all. turns over and there is gas to the TBI, but it is not getting to the injectors, could this possibly be a computer problem??????
Old 08-04-2005, 09:22 PM
Morley Morley is offline
Re: Re: 92 camaro rs that won't stay running
The ECM will not fire the injectors if it doesn't see a refrence pulse from the ignition module.
