Old 08-04-2005, 01:48 AM
Dr.Gigglez's Avatar
Dr.Gigglez Dr.Gigglez is offline
Exclamation Help Me Paint My Accord...
Ok Folks So heres the Deal...Want to paint the bottom of the Accord gun metal and the top a racing blue... split like the picture below...
how do i do this?....paint the whole car blue first then tape off the top and paint the bottom GM....or GM then Blue?....or shit i have no idea how to do this...anyone know?
Thanks for the Help!!
-Paul A.k.A Dr.GiggLeZ
Old 08-04-2005, 03:14 AM
spitfire143 spitfire143 is offline
Re: Help Me Paint My Accord...
Light First, Dark Last. You picture doesn't work so I can't see what you are asking really.
Brakeneck.com
Old 08-04-2005, 08:45 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Sounds like you are going to use Tamiya sprays. If so...
Paint the whole car Racing Blue, even what you want to be Gunmetal. It will take at least two coats to cover, but you are better off with three light to medium-light coats.
When fully dry, mask and spray the Gunmetal.
The Tamiya Gunmetal doesn't cover as well as some of the other colors, that is why you need a uniform finish under it before painting.
Build it up in a minimum of three LIGHT coats to get the color density.
Take your time and it should look nice... - Mark
Old 08-04-2005, 04:42 PM
Dr.Gigglez's Avatar
Ok...I fixed the thread thats a crapy example of what i want to do...but i used paint...but thats the basic idea...so i do light then dark? and do i tape it off with masking tape?
Old 08-04-2005, 06:12 PM
alakai's Avatar
alakai alakai is offline
Send a message via AIM to alakai Send a message via Yahoo to alakai
Exactly. For your project, racing blue first then gunmetal. Be sure to mask carefully in order to reduce the chances of the dark color bleeding into the light color. I've had good results with spraying a light mist of clear after masking, which helps prevent bleed through.
Old 08-04-2005, 09:24 PM
Dr.Gigglez's Avatar
ok sorry guys...COLOR change...Its going to be a Light ICE Blue and then Daytona blue so again light blue first...then mask off front and spray the dark blue second....mist layer so no bleeding?...
Old 08-04-2005, 10:55 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
The best advice here is to do the mist between colors. A general rules is to spray dark over light, but it's not always the case and the knowledge comes from experience. If you're doing two blues: Prime it! to avoid paint liftoff witht he maskint tape, spray the whole car the light blue, WAIT!!! for the light blue to cure so the tape won't lift it off, mask it, spray a light coat of the light blue over the masking, spray the dark blue, remove the tape while the paint is tacky NOT wet and NOT dry, and there you have it.
Old 08-05-2005, 11:55 PM
Dr.Gigglez's Avatar
ok when u say not wet but not dry...that means i would only do one coat of dark blue or do i do more?
