Hey all, I'm new, and I searched for a thread with the answer to my problem, but didn't find one... here is my issue:
When I have either the Normal A/c on or just vent selected, 1) is it normal for the air to come out of the top vents in the dash (near the windshield) when i accelerate? (usually this happens around 3000 rpm or after 65/70 mph) 2) If it isn't, then what could possibly be causing the problem? Any help would be appreciated... i just got my 95 black lt 4 door 4wd blazer and i love it, but that bugs me! |
Re: Weird Occurrence with vents
No, not normal, you have a vacuum leak, trace the vacuum lines going to the vacuum ball in the engine bay.
Driver's side firewall corner.
1995 Factory Blazer Service Manual for sale, PM if interested. |
You know what. I am going to start answering more questions. I think I have learned everything I need to know about Blazers now. I will tell people "check for a vaccum leak".
![]() Just joking, seriously though I got the same problem with mine. I never really cared much about it though because it always goes back to the vents a few seconds later. I may go check it out since I am goin to go stare at my Blazer some more in a bit.
Red 1995 Chevy Blazer 4X4 Check it out. http://www.cardomain.com/ride/2071240 MODs Brush Guard 2/20/05 Bigger tires 3/15/05 Flowmasters 6/18/05 Minor Paint work 2005 Upcomming 6 inch lift 0-6 months Swampers 0-6 months Dual Flowmaster Exaust 6-12 months |
RedLT,
You would be amazed as to how much vacuum controlls this engine.
Re: Re: Weird Occurrence with vents
Thanks for the information, I'll check that now, because it's been really bugging me. Nice car btw. looks like i want mine to look |
Your truck's a '95 with the CPI, RedLT? Easy to find it. Take a peek between the tensioner's idler wheel, the underside of where your air intake leads to the plenum, and just above the pulley of your water pump. See that black, round, plastic thing with the 4 wires in a connecter sticking out straight back at you? That's your EGR. I have had mine off several times to clean it as the truck went through a phase of "couging up a lunger" - twice it got stuck completely open or shut, each time it was because of a chunk of carbon in it. She's quieted down after having to come off three times total. I am waiting for it to stay clear for a while and then I will give it a fresh gasket I have sitting in the back of the truck. I was lucky and able to salvage the new gasket put on it after the first time it came off two more times, but it's good to be sure and have it put back on every time with a fresh gasket. My reluctance is only because of the wait time involved in getting the right one shipped in, they're cheap - but nobody *stocks* them. Not here anyway.
Re: Re: Re: Weird Occurrence with vents
still working...
okay, well i changed the vacuum lines, which were very badly deteriorated, but the problem still happens... my mechanic (who was nice and didn't charge me to do an inspection) said it might be one of the vacuum valves, and will check for free. he said the fix might cost about $40.
Although this might be another problem... sometimes there is a buzzing noise coming from the windshield defroster vents... it happens occasionally, and isn't electronic or anything... is this the same problem or different, y'think? |
Did you check the connection going to the vacuum ball?
Re: still working...
how much would a vac leak affect the gas mileage? i know it would effect the idle. right now mine at idle sounds like it has a cam in it. i don't know if its from the cat taking a dump or vac leak. i do have the same prob with the vents though. everything looks good also.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system. 71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out. 90 cav, 2.2 tbi, gas getter. 99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed. |
Does it rev up and down constantly?
nope. just idles like theres a cam in it.
