Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 08-03-2005, 09:57 PM
BrianNJ BrianNJ is offline
PCV Valve location 97 Civic LX Manual
Can some one pl. help me locate PCV Valve for 97 civic LX 5 Speed Manual trans. Thanks in advance
Old 08-04-2005, 10:00 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: PCV Valve location 97 Civic LX Manual
its on the intake manifold under the runners; if it is th same as a DX that is. It is easiest seen standing on the left side of the car and looking down over the manifold. You will probably need a light and a damn monkey's arm to get to it. it is actually easier to get to from the bottom if you have a small arm and can twist alot.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
