Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 08-03-2005, 07:15 PM
93smoothcelica 93smoothcelica is offline
Angry 93 Celica 5th Gen. will not start
Having a problem with my 93 celica, seems to be a rare find. It's a 93 with a 5th Gen. engine. One day while driving along it started spuddering to a stop as if it had ran out of gas. However, this was not the case, I have tried the following:
1. Changed the timing belt, However, to find that the old belt was just fine.
2. Changed the fuel pump.
3. Changed the fuel regulator, verified that it is getting fuel to the rail.
4. Checked the ohmage values at the distrubutor, coil, and ignitor. They check out fine.
5. Varified that it's indeed getting spark.
6. Last but not least checked all of the vac. hoses.
.....and after all of this it just turns over without starting. However, every now and then it tries to start and will one out of hundered starts run fine at idle, but quickly dies if you give it gas. What am I missing here. At my whits end... ....taking all suggestions!!!!!
Old 08-03-2005, 09:43 PM
jaybratt jaybratt is offline
Send a message via AIM to jaybratt Send a message via MSN to jaybratt
Re: 93 Celica 5th Gen. will not start
You made sure your battery was fine right? I had that happen once and my alternator had come loose and within two minutes my lights and stereo killed the battery.
My Trac
Old 08-04-2005, 06:15 AM
Yes, the battery is fully charged, but it just turns over and over without starting.
Old 08-04-2005, 01:21 PM
Vip09 Vip09 is offline
Send a message via AIM to Vip09
A 1993 Celica IS a 5th gen...
Best GT-S STOCK times: 1/4: 14.788 @ 94.98mph 1/8: 9.640 @ 75.87mph
Best Alltrac times: 1/4: 13.3 @ 102mph (older setup) 1/8th: 7.8 @ 83mph (old setup)
Old 08-05-2005, 08:44 AM
Im fully aware of that, what I mean is that it's hard to find one that has been junked. You find 3gen engine parts by the dozen, but to find a 93 celica is just very rare I've looked.
Old 08-01-2009, 04:26 PM
tj9924 tj9924 is offline
Have you found the problem? I am having the exact same problem with my Celica. I am working on it today so if I find it I will let you know.
