Firewall Water leak
I had my car towed to a dealer and was told there was a water leak on the firewall. This apparently got water inside my car as well as the BCM and other areas inside the vehicle. They have to fix the leak, pull up and dry out the carpet, dry out the BCm etc and check for any other leaks and seal and repair them. They are wanting $375 for this. Seems a bit high to me but it also seems labor intensive. Since it is currently inoperable I really don't have much of a choice. Just wondering if this was a fair deal (considering it is a dealership.)
Re: Firewall Water leak
Honestly, sorry to tell you the truth, but since it is a dealer, I would say that is a typical price. I'd say it's fair.
Blam-o I posted this tid bit from a GM dealership monthly, I had leaks too but the Dealers I took mine to was not able to find it, but I did and this article explains how to fix it. Maybe it's the same or close to what you've got. \,,/ \,,/
Front Carpet Passenger Side Water Leak Owners of some 1999-2001 Alero and Grand Am models may comment about a mildew odor, windshield fogging, or wet carpet on the passenger side. And in ambient temperatures below 32° F, the blower may not operate due to ice. The foam water dam under the black beauty panel may be mis-positioned, missing, or not adhered properly. On vehicles with foam mis-positioned or not adhered properly Remove and discard the original foam part. Clean the metal surface with an alcohol based cleaner. Install the new part, properly center-ing the part over the HVAC air intake opening. On vehicles built without a foam dam and old style beauty panel Install 18 mm foam. On vehicles with no foam, or with 18 mm foam and new style beauty panel Install 25 mm foam. – Thanks to Ray Romeo |
