Old 08-03-2005, 05:54 PM
cnogood cnogood is offline
Send a message via AIM to cnogood Send a message via Yahoo to cnogood
paperclip code reader
Ok some1 said I can read da flash codes with a paper clip. I have a 89 rs. Can some1 walk me through da steps how 2 do dis with a paper clip. Thnx
Old 08-03-2005, 06:11 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: paperclip code reader
GM Trouble Code Info
Accessing Trouble Codes
  • Turn ignition switch to OFF position
  • Locate Data Link Connector (DLC), see image below.
  • Jumper the A&B terminals(a paper clip or a jumper wire work ok)
  • Turn Ignition switch to ON position.
  • Count the flashes on the "CHECK ENGINE" or "SERVICE ENGINE" light.
  • FLASH, pause, FLASH, FLASH = code 12
  • NOTE: Some 94 & 95 models do not have the B terminal. In which case a scanner is required.
  • NOTE: Some 94 & 95 models that DO have the A & B terminals still require a scanner.
  • All vehicles after 96 are OBDII,and require a scanner to access them.
12 Pin DLC
A - Ground
F - TCC
B - Test Terminal
G - Fuel Pump
C - Air Injection
H - Brake Sense Speed Input
E - Serial Data
M - Serial Data
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 08-03-2005, 09:39 PM
Viper_Storm's Avatar
Viper_Storm Viper_Storm is offline
Send a message via AIM to Viper_Storm Send a message via MSN to Viper_Storm
lol, you can search for ODB I and it should bring up a big ass list of ODB I codes, some dude made both (ODB I & ODB II) lists and they are here, may not be 100% complete
All Throttle, No Bottle!
Torque Makes You Go... FAST!
Horsepower Is For Braggin Rights.
Money talks, But all mine ever says is Goodbye
~Viper
"twospirts" / "TS" - Definition: Obsolete
