Old 08-03-2005, 05:31 PM
harryfatchick harryfatchick is offline
interior lights dont work
all interior lights dont work there is a 10 amp fuse and when i try to replace it keeps blowing. Any one know wht this would o that. it is like there is a short some where? any help would be great thank you.
Old 08-04-2005, 05:35 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: interior lights dont work
If the fuse keeps blowing then you do have a short somewhere. If the fuse blows when you open the door then check the door activator switch. Also check each light by removing them from their mounting place and look at the wiring. One other place to look is the area where the wires go between the body and the door.
Old 08-04-2005, 10:42 AM
gtp'n gtp'n is offline
Had the same problem with mine. The short was in the driverside visor. Took me a month to find out where it was. I finally had to replace the fuse and just started playing with everthing in the car until I found it. Dealer replaced the visor under warrenty
