Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 08-03-2005, 04:58 PM
rhclay619 rhclay619 is offline
2000 LS A/C Problem
Could not find a thread with this problem, so let me know if anyone has an idea. The passenger side dash A/C vents are blowing warmer air than the the driver's side. Considerably warmer air. The passenger side temp is set at the same as the drivers side. HELP! No engine codes are showing. Driver's side is ice cold.
Old 08-04-2005, 07:36 AM
Quik_LS's Avatar
Quik_LS Quik_LS is offline
Send a message via MSN to Quik_LS
Re: 2000 LS A/C Problem
Common issue in older LSes. The blender valve gets stuck - and one side ends up at a completely different temp than the other.
Most of us have had it happen once or twice - usually letting the car sit overnight - the problem goes away.
If it keeps returning - the blender vavle may need to be replaced. Not a small job - since most of the dash has to come out....
Quik LS - Austin, TX
more, more, more.....
#0018 ESP SCCA solo2
LLSOC.com - President
see my mean LS
see my Lotus Esprit - Quiker
Old 08-04-2005, 09:10 AM
lskoncepts's Avatar
lskoncepts lskoncepts is offline
This has happened to me while my LS was under warranty and the dealer fixed the problem under TSB 03-3-4. Below is an excerpt from that TSB.
A/C - Lack of Cooling From Driver/Passenger Vents
Article No.
03-3-4
02/17/03
CLIMATE CONTROL - LACK OF COOLING FROM
DRIVER AND/OR PASSENGER SIDE VENT -
VEHICLES EQUIPPED WITH DUAL AUTOMATIC
TEMPERATURE CONTROL (DATC) ONLY
FORD:
2002 THUNDERBIRD
LINCOLN:
2000-2002 LS
Article 00-15-3 is being republished in its entirety to update the models covered and to update the Basic Causal Part number.
ISSUE
Some vehicles may exhibit a lack of A/C cooling from either the driver or passenger side vents or an extreme temperature difference between the driver and passenger side on vehicles with DATC (Dual Automatic Temperature Control): This may be caused by a faulty DCCV (Dual Coolant Control Valve), a faulty DATC control assembly, or faulty electrical circuits.
ACTION
Inspect and service as necessary, electrical circuits, DCCV and DATC control assembly. Refer to the following Service Procedure to aid in diagnosis and repair.
Parts Block
OTHER APPLICABLE ARTICLES: NONE
SUPERSEDES: 00-15-3
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION DESCRIPTION TIME
030304A Diagnosis (Includes Time 0.5 Hr.
To Perform All Diagnosis
Mentioned In This Article
Can Be Claimed With Or
Without Part Replacement)
3.0L/3.9L Engine
030304B Additional Time To 1.7 Hrs.
Replace Dual Coolant
Control Valve - 3.0L
Engine
030304B Additional Time To 2.0 Hrs.
Control Valve - 3.9L
Engine
030304C Additional Time To 0.6 Hr.
Replace Dual Automatic
Temperature Control
Assembly: 3.0L/3.9L
Engine
030304D Additional Time To Repair 0.4 Hr.
Wire - 3.0L/3.9L Engine
DEALER CODING
CONDITION
BASIC PART NO. CODE
18495 42
OASIS CODES: 208000, 208200, 208999
Ken Garrison
2001 Lincoln LSE
Pics of my 2001 Lincoln LSE!
LS Koncepts
Luxury Sedan Aftermarket Parts
Old 08-06-2005, 10:01 PM
Article No.
03-3-4
02/17/03
FORD:
2002 THUNDERBIRD
LINCOLN:
2000-2002 LS
ISSUE
ACTION
Parts Block
SUPERSEDES: 00-15-3
3.0L/3.9L Engine
Engine
Engine
Temperature Control
Assembly: 3.0L/3.9L
Engine
DEALER CODING
CONDITION
BASIC PART NO. CODE
18495 42
Thanks guys, you are the greatest! I will contact the Lincoln dealer...
Old 06-30-2006, 05:00 AM
jerryls jerryls is offline
I have a 2000Ls V8, with this problem. What part of the dash do I need to take apart to get at this valve? I get super hot air on the right side and what feels like a mix of cool and hot on the left.
Thanks for any information.
