Old 08-03-2005, 05:55 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Engine rebuild...might as well stroke it?
Searched, couldnt find exactly what I wanted, so:
Lately, I've been fearing the worst from all the knocking and ticking sounds coming from under the hood. Car goes to shop tomorrow.
Considering I may need an engine rebuild, with new pistons and rods (car has 125K miles, recently driven hard by me but only 10psi boost), I thought I might as well pay a little extra and get a stroker kit, in anticipation of a larger turbo later on. (Though I HOPE I wont need any heavy duty work under the hood right now, I was hoping to squeeze more life out of my engine, but you never know what the mechanic says tomorrow).
1) Which stroker kit should I get with so many on the market? I was looking at SBR, but they had different rod and piston combos. I eventually want to run a bigger turbo with AFC, so I thought I might as well lay the grounds for the setup now, as opportunity presents itself, instead of having to stroke it later on.
2) I live in CA, and smog is always a PITA. Would a stroker throw on a check engine light? Would the ECU be needed to be upgraded in any way to accomadate the stroker?
Thanks. I really hope that knocking/ticking sound isnt what I think it is Here's the link for the thread I posted concerning that issue:
http://www.automotiveforums.com/vbul...79#post3293079
The daily driver. The weekend cruiser. The lazy shop hog.
Old 08-03-2005, 09:38 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Engine rebuild...might as well stroke it?
replace it with a 6bolt, or just stroke the 7bolt?
DSM geek
Old 08-03-2005, 10:46 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
I hope DSMlink is on your list. The stroker question is just a matter of money. The extra torque will be nice and you'll laugh at turbo lag. Downside is that you have to add (2.3) to all of your sentences because nobody will understand how a 60-1 spools like a 14b.
Old 08-04-2005, 12:51 AM
Shpyder's Avatar
Moderate moderator
Re: Re: Engine rebuild...might as well stroke it?
DSMlink is on the list for sure, but a large concern for me is the CEL and passing smog. I wouldn't want to "un-stroke" the car 2 years from today to pass smog, lol. The smog guy says that stroker kits arent a problem as long as the car isn't running rich, and enough of the fuel is burt up .
I just took the car for a drive and the knock sound is worse and louder. I'm hoping against hope that it's just a bad plug or something cheaper to fix for now.
But if it does happen to be an engine job, Joe, you said its a matter of money for a stroker kit. What stroker would you get if you had a $1500-$1700 price range? I'm basically looking for something in between a basic stroker kit and a high end one, something that's middle ground cost and performance wise as far as strokers go (whatever that mean, lol). A kit that can handle good boost and high RPMs. I eventually want to run a SBR TDO6H 20g, Kevin regards that as a good streetable turbo, and hence so do I God, I want everything, don't I.
Old 08-04-2005, 02:48 AM
MexRocket's Avatar
MexRocket MexRocket is offline
well i was told buy the car expert himself TEDX that if you get a stroker kit, the car doesn't rev as high becuase, well because thats all i remember as him
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 08-04-2005, 02:51 AM
kjewer1 kjewer1 is offline
AF - Advisor
20g will be way too small on a strocker. I wouldnt go smaller than a GT35R. The extra 20% displacement moves 20% more air at the same boost I ran the same 56 trim wheel in a TDO6H configuration and had full boost (25 psi) by 3700 rpm, or the same rpm I had 25 psi at with a 2 liter and 6H 20g, for reference. You can run whatever variant of the 35R wheel you want, but I wouldnt go smaller.
I never bought a stocker "kit." Its just the crank and pistons. Rods are the same as what you would normally use. I was using eagle rods, which obviously held up fine to all of my abuse. They are cheap too. Figure about 300 for a crank, 300 for rods (IIRC), and 400 for pistons. The rest is all machine work you would have to do anyway, I pay around 500 depending on what needs machining. Running a stroker will have no effect on emmissions, the ECU still does it job the same way it always has. Thats the beauty of mass air systems
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-04-2005, 08:51 PM
JoeWagon's Avatar
Banned
If you buy a kit, make it because a vendor is packaging it so that you save money. It doesn't matter who, really, because you'll need to select your components anyway. I assume you're looking at 2.3 from a 6 bolt 4g63 block. Magnus has a lot of piston options, but don't ask me what's worth it or not. http://www.magnusmotorsports.com/Pistons.htm
So, Kevin...
Old 08-05-2005, 01:45 AM
Shpyder's Avatar
Moderate moderator
If you buy a kit, make it because a vendor is packaging it so that you save money. [/url]
That was the main drive behind getting a "kit", because purchasing the parts separately would be a little more expensive. I e-mailed RRE, and they want to do a 6-bolt swap and a 2.3 stroker on that. I told them that I was hoping my motor wasnt blown yet, but theyr'e like "get it done anyways!". haha.
Well, I'm now losing boost and power accross all RPM ranges and gears, and the knocking noise is louder (similar to an VW microbus, or a a 60's bug). Very scary stuff. Car goes to shop tomorrow morning, and I'm hoping its just a timing / spark issue, and not a rod knocked lose or something horrifiying like that . The mechanics are people I know and do great work, but their DSM knowledge is limited. Since RRE is 1.5 hours driving north of me, and the engine does turn out to be fcked, I'll probably knock and tick my way up there to drop my car off to them.
I hope its not that bad I hope its not that bad I hope its not that bad. Amen.
Old 08-05-2005, 01:58 AM
AF - Advisor
Magnus QPD pistons are the nuts, I can now personally attest to this. We were tuning a friends car on the street with w dual intank 255hp fuel system, and were running out of fuel. Badly. Like 16:1 AFR badly... The motor survived! Repeatedly! Rock out with your cock out...
For the record, the problem was fuel slosh at high Gs starving both pumps. Who would have thought. Its most likely going on a dyno tomorrow to verify this (the car wont be moving, makes it easy).
Kevin Jewer
Old 08-05-2005, 09:23 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I have a question about strokers too. If someone were to get a 2.3 kit, how much would they have to bore the block over?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-05-2005, 10:13 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
I'd be willing to bet your car wont make an hour and a half drive... I would just tow it up there if it's f*cked man. Otherwise there's the chance you'll be stranded on the road for several hours.
Also i'm still new to imports, but when you stroke something it's usually because you're trying to more power in lower RPM's, or is it different with 4 cylinders?
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 08-05-2005, 10:18 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Here's a kit that's close to the price of buying everything seperate (I was planing on doing a stroker so i did some research) http://carshop.carshopinc.com/produc.../59245/CS23KIT
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-05-2005, 10:40 AM
AF - Advisor
Thats the case on low reving V8s, but with 4g63/4s, poeple are still taking then to ~8500 rpm. I know I was. So the benefit becomes more about the added 20% displacement moving 20% more air, without having to run a turbo that wont spool on a 2 liter till very late. 20% more airflow at the same boost is 20% more power at the same boost.
The overbore will depend entirely on what the block you are building needs. Typically you'll end up with a 020 over bore just to get to clean material in the block to start fresh. Sometimes the block is in real good shape and it just needs a hone, but this is uncommon. A block that was blowed up might need 040 or 060 to get all the scoring out. It has a minimal effect on displacement, 95% of the increase comes from the significantly longer stroke.
Kevin Jewer
Old 08-05-2005, 12:18 PM
Well if you decide to go with a 6bolt swap stroker call me at my work (509)922-1450. I work for Hyundai, and can get you a new Forged 6bold g4cs 100mm crank at 10% over dealer cost. $462 and some change. I havn't checked on the g4cs big rods that come in that Sonata. but from what i understand they are as strong, if not a little stronger then the 1g's. Also heard the Main caps are stronger, never the less i dont mean to pollute your thread. open invite for AF guys.
It's the setup im going to run next year.
DSM geek
Old 08-05-2005, 12:29 PM
-Josh-'s Avatar
Re: Re: Re: Engine rebuild...might as well stroke it?
So it's just for power when turbo isn't spooling or spooled up all the way. Makes sense, but .040+ for machining the cylinder walls seems like an awful big cut to me. Is it pretty safe to bore it out that big without sleeves or anything? Wouldn't it be better just to replace the block if you're going to bore it out that much...it just seems like cylinder walls would get awfully thin on a 4 cylinder pretty quick.
AF User Guidelines
