Old 08-03-2005, 04:24 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
quick heatshield question
Is at absolutely necessary to have both the top and bottom heatshields on? Im feeling really lazy right now after the 16g install and wondering if i can just leave them off for a while until i have time to put them on. thanks guys!
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 08-03-2005, 06:11 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: quick heatshield question
It should be fine to run without them.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-03-2005, 06:24 PM
4G63t Power 4G63t Power is offline
Dont put them back on period. You dont need them. As long as you have the heat sheild on your hood it wont do a thing. It keeps the turbo cooler and its SOOO much easier to work on the turbo or around it. They are not necessary and are only there to keep curious new owners from touching the 800+ degree components (manifold and turbo).
AWD sold
New car*
90' Eclipse Gs-T
Shaved head with rebuilt motor
Slowboy racing limited slip
compression 165 across the board (:
Fully ported Big 16g with 34mm flapper
Precision racing Fmic
Slowboy Boost controler set at 15lbs
Custom 3 inch turboback
Fully ported o2 housing
Ported 2g manifold
Slowboy racing UICP
3 inch hard intake pipe
SAFC
Autometer carbon fiber gauges
Putting down a solid 300whp
1/4=13.7 at 109
That mph is good for high 12's with traction (:
Old 08-04-2005, 03:26 PM
ted_ex's Avatar
ted_ex ted_ex is offline
First off, the turbo works off of heat. Expanding air moving in the path of least resistance. So anything that keeps the heat in (at least on the exhaust side) helps. Second, look how close the alternator is to the exhaust. I burned up 2 alternators and completely melted the AC fan because I didn't put the heat shields back on after I installed my big 16. I was running 18psi daily driven and sitting in traffic you have very little air flow. Granted, I was driving the car a LOT, but I still think it's a good idea to put them back in place. I cut my bottom shield around the O2 sensor cause that little slut wouldn't come out.
tedX
I'm>everything
Old 08-04-2005, 04:37 PM
MexRocket's Avatar
MexRocket MexRocket is offline
yah and i just went through one altenator due to crappy exhaust, and no heat shields, and ted is a wizard!
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 08-04-2005, 07:20 PM
Okay cool guys thanks...Ill put it back on when i have my next day off.
My Car
