Old 08-03-2005, 01:49 PM
USMCFR USMCFR is offline
Exclamation Engine Problem
Alright this has been goin on for atleast a month with me trying to fix it. I bought this car off of my dads freind and he said i need a new starter and alternator.
I buy them both, both are installed and ready. I plug the alternator up and the battery. sparks come off the battery and the main fuse blows.
Ive probably went through 10 fuses and the engine still wont turn over. I have narrowed it down to the alternator becuase each time i plug the alternator up the fuse goes BOOM.
And i almost forgot to mention, its a 1991 Mercury Tracer... but an escort is the closest thing to it on this forum.
Anyone have any help or advice ? (serious advice)
Old 08-03-2005, 02:23 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Are you hooking up the alternator then the battery? If so, I'd say that the cable going from the battery to the alternator is grounded out somewhere. That's why the fuse blows-it's supposed to. If you have a test light try this: Make sure the ground is hooked up on the battery. Run the test light from the positive terminal on the battery to the positive battery clamp. If the light comes on then you have a grounded cable.
Nevada Tumbleweed
Old 08-03-2005, 02:31 PM
jeffescortlx jeffescortlx is offline
Send a message via AIM to jeffescortlx
Re: Engine Problem
Either you have a short like he said, or your hooking up the battery backwards.
I make slow Escorts less-slow.
My cardomain
Old 08-03-2005, 10:18 PM
no im not hooking the battery up backwards.... thats the reason i had to get a new alternator, someone who had it before me hooked the battery up backwards. but ill try the light test in th morning..
Thanks, ill keep you guys informed of what i get so you can help me out
Old 08-04-2005, 12:36 AM
riccbhard riccbhard is offline
If the person before you hooked it up backwards; and it's still the same battery; wouldnt you think the battery would be shot?
Old 08-04-2005, 10:59 AM
Re: Engine Problem
different battery
Old 08-05-2005, 11:36 AM
Did you try the test light?
Old 08-05-2005, 02:44 PM
Re: Engine Problem
I cant find it......
Old 08-05-2005, 09:25 PM
Bobbywolf Bobbywolf is offline
Re: Engine Problem
A multi-meter to measure the voltage will work just as well.
